FS: ST MAY electronic boost gauge with peak warning and playback.Here you go. Upgrade that pos mech
Old Feb 25, 2005 | 02:53 PM
ButteroJ's Avatar
Default FS: ST MAY electronic boost gauge with peak warning and playback.
Here you go. Upgrade that pos mechanical boost gauge to this. We all know electronic boost gauges are faster responding and more accurate. The gauge measures 60mm in diameter, measures up to 2.5 bar of boost, has a white face and is back lit red. The Adjust function will allow you to set your maximum boost at which the gauge will flash on and off to alert you. The gauge is also equipped with the Play Back Function. The gauge comes with the head unit, pod style mount, power harness, external boost sensor and head unit to boost sensor harness. All you will need is some hosing to run the sensor.
$125 shipped o.b.o.
Old Feb 26, 2005 | 06:45 PM
ButteroJ's Avatar
Default Re: FS: ST MAY electronic boost gauge with peak warning and playback. (ButteroJ)
Old Mar 2, 2005 | 03:45 PM
ButteroJ's Avatar
skuded
Apr 21, 2011 04:38 PM
FRernesto
Aug 29, 2007 07:01 AM
hondaaccord94
Aug 9, 2006 05:19 PM
