Do you guys think the B18C1 is a better candidate for FI or NA?
what do you have done to your gsr now? kinda makes sense to build off what you got. id say turbo though
I'm not a fan of Turbo+VTEC. I say get a supercharger and a 55shot of N20. That should be quick enough for most people.
yeah, vtec sucks for turbos....
Best e.t.: 8.12 seconds
Best speed: 180.00 mph
Career highlights: First Honda to break 9 seconds
First front-wheel drive to break 8 seconds
First front-wheel drive to break 160 mph
First front-wheel drive to break 170 mph
First front-wheel drive to break 180 mph
2000 NIRA Pro Comp Champion
2000 IDRC Outlaw Class Runner Up
2001 NIRA Pro Front Wheel Drive Points Champion
[Modified by jinxproof99, 8:42 PM 1/20/2002]
Just curious. I'm still debating on the next level for my B18C1 hybrid CX.
hows this for a stock block 1995 b18c1:
11.38 @ 125 mph
daily driven
jinzproof99 ~ how much boost are you running on your stock B18C1 block?? How many miles are on your engine?
Thanks,
Todd
Thanks,
Todd
Some of these guys up top are confused...
Todd definitely go with the turbo if your looking for bigger power gains.
By the way I'm selling my T3/T4 and downpipe if your interested.....
Adi
b18c1 is a great platform for na or fi compression is not to high for turbo but not to low for na
u have to set ur goal..like how much power n how fast u wanna go..
then decide the best way to do it..
personally..i wouldnt go all drag racing..
i would want a full interior set up..so ill boost my car..and probably spend 4-5k max..
the b18c1 at 12psi vs. b18a at 12psi...the b18c1 will win..
Guest
Posts: n/a
BTW, VTEC engines do like boost, but there's more tuning involved over, say a B18 or B20.
What application? Drag, Street, AutoX, Open Track, ECHC? If it's anything but Drag or Street, I would probably stick with reliability and smooth response of NA, and spend my money on suspension, any necessary safety equipment, and then consumables (track time, tires, brake pads, rotors, fluid, etc.).
I'm guessing you're more interested in Drag/Street, so perhaps Turbo or nitrous might be a better route to jollies for ya. Check into what's legal in your area.
Turbo that monster. I plan on doing it to my hybrid 5th gen B18c1. The question for me is:
A. What kit to buy?
B. Should I piece it together?
Will I be able to have A/C?.......just kidding.
A. What kit to buy?
A. What kit to buy?
A. What kit to buy?
If you don't know that much about turbo systems and how they go together and operate or even if you have a little knowlidge about them I would just go ahead
and buy a kit and save yourself the hassle.....
On the other hand if your pritty experianced and have turbocharged a car before and know all of the components It would be smarter for you to peace a turbo kit togther or just buy the max rev kit and get a pump because that kits components are really good right out of the box..
Adi
Thanks,
Todd
Thanks,
Todd
LS = Turbo
GSR = NA
GSR = NA
420 huh, you must smoke alot of weed to come up with that. gsr would NOT be my choice for na and the ls would only be a choice at all if it had 87 mm pistons, oil squirters, a vtec head, bla, bla, bla...............
That engine is not a VTEC motor anymore. The VTEC is disabled.
my point was to show that the top drag racers use vtec heads. he used vtec for along time and almost EVERYONE else still uses it. in fact, the most popular honda motor for f/i today is the b18c1. built block, ported head, and stock gsr cams produce well above 600 hsp to the wheels.
A. What kit to buy?
A. What kit to buy?
don't buy a kit. piece it together.
If your planning on keeping this car as a daily driver, in hopes of cranking out well over 100,000 miles, I'd say go with N/A. However, in going N/A, expect to spend near $8000 to see the kind of gains you can see with a Turbo charged setup and slight tuning. I'm planning on going N/A, mainly because I can pretty much retain stock parts and still push 200whp. However, it's gonna take a lot of money and some real tuning. You can't compensate for Turbo power, especially at the cost. However, with a GS-R, I'd go for N/A, partly because I'm biased and I like to waste money, but would rather retain the more reliable stock parts.
