94-97 Integra ABS REMOVAL, help!
Old Feb 25, 2005 | 12:34 PM
BoOsTiN Dc2's Avatar
Default 94-97 Integra ABS REMOVAL, help!
I have a 95 integra and i want to take out my ABS because it is not working anyway. I want the extra room for my engine bay and i want it to look cleaner. I've searched and i saw a post for 98-01 integra all you have to change is a RS prop valve 40/40. What about for a 95 integra? Do i need to change the prop valve, mc, front brake lines, and more stuff? or do i just need to change certain stuff? Please dont post if your gonna ask why do i wanna do this or anything thats not gonna be helpful, i've seen enough post about this removal and can't find that much useful info because of people saying stuff thats not related to the removal of this.
Old Feb 25, 2005 | 02:32 PM
skunked's Avatar
Default Re: 94-97 Integra ABS REMOVAL, help! (tRaCeBuStAbUsTeR)
I removed the ABS in my 94 GSR. You will need a proportioning valve from a non abs 4 wheel disk brake honda and you will need to bend 4 brake lines (master cylinder to the proportioning valve and from the valve to the front brakes). I bought the brake lines from a local auto parts store along with the bending tool, flare tool and a small pipe cutter to cut the brake lines. Let me know if you have any questions.
Old Feb 26, 2005 | 01:05 AM
Default Re: 94-97 Integra ABS REMOVAL, help! (skunked)
so basicly the master cylinder and the brake booster i can use the stock gsr one right? what kind of car has non abs w/ 4wheel disc? rs integra, 99-00 civic si, what else? if i use rs brake lines then i wont need to bend and cut the gsr brake lines?
Old Feb 26, 2005 | 09:48 AM
skunked's Avatar
You can use the gsr master cylinder only if you bend your own custom lines. If you use the rs brake lines you will need a rs master cylinder because the outlets are different on the RS vs GSR (different brake line inlet/outlets). I think I got my proportioning valve out of an old non abs teg with 4 wheel disk.
Old Feb 26, 2005 | 03:26 PM
integrator43's Avatar
i just got the complete setup from a EG Si it bolted right in with very minor bending. easy to do by hand, and very cheap from the junk yard $25.00
Old Feb 26, 2005 | 08:37 PM
if i reuse the stock gsr brake line is there gonna be a lot of modification involved in the brake line?
Old Feb 26, 2005 | 10:21 PM
skunked's Avatar
you can't use the gsr brake lines.
Old Feb 27, 2005 | 02:07 AM
ok so what is my option right now? rs prop valve and brake line or 4 wheel disc prop valve and?
Old Feb 27, 2005 | 08:50 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">ok so what is my option right now? rs prop valve and brake line or 4 wheel disc prop valve and?</TD></TR></TABLE>
You need to replace your proportioning valve either way because the ABS unit is your proportioning valve right now.
Try to find a RS and take all the parts off it (proportioning valve, 4 brake lines and master cylinder). You would just need to bolt everything up.
Or buy a proportioning valve and fab your own brake lines.
Old Feb 27, 2005 | 11:34 AM
oh i thought i only need to change 2 brake lines. so i have to change all 4?
Old Feb 27, 2005 | 01:20 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I removed the ABS in my 94 GSR. You will need a proportioning valve from a non abs 4 wheel disk brake honda and you will need to bend 4 brake lines (master cylinder to the proportioning valve and from the valve to the front brakes). I bought the brake lines from a local auto parts store along with the bending tool, flare tool and a small pipe cutter to cut the brake lines. Let me know if you have any questions.</TD></TR></TABLE>
Old Feb 27, 2005 | 01:36 PM
B20TDC2's Avatar
https://honda-tech.com/zerothread?id=1160671
check out this thread it should help
Old Feb 27, 2005 | 08:53 PM
Default Re: 94-97 Integra ABS REMOVAL, help! (B20TDC2)
thanks for all the info and the write up
Old Feb 28, 2005 | 12:58 AM
TurboLSVtecTeg's Avatar
goto my sitehttp://www.turbolsvtecteg.com and read on my update page about my brake install. PM if you have any questions.
Sal
Old Mar 6, 2005 | 02:04 AM
Default Re: 94-97 Integra ABS REMOVAL, help! (TurboLSVtecTeg)
i found a 91 integra LS proportioning valve, would this work for my 95 gsr? and if i get this proportioning valve does it mean my only choice is to do custom stainless steel lines? http://cgi.ebay.com/ebaymotors...=WDVW
Old Mar 6, 2005 | 09:35 PM
bump
Old Apr 27, 2006 | 12:34 PM
TA Performance's Avatar
Default Re: 94-97 Integra ABS REMOVAL, help! (BoOsTiN Dc2)
can i still use my 94-97 integra LS booster and mc for the abs removal?
from what i understand right now is:
if you use your gsr mc you cant use RS brake lines?
and if you use RS mc you can use the RS brake lines?
Old May 3, 2006 | 11:03 PM
guymosiris's Avatar
Default Re: 94-97 Integra ABS REMOVAL, help! (TurboSpirit_DC2)
I would also like to know this. I'm removing my ABS in a GSR, but will use stainless braided lines for the brake lines. Does this mean I can keep my oem GSR MC/BB and just buy a prop valve? If so, it'll save me $100.
Old May 4, 2006 | 08:00 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSpirit_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">can i still use my 94-97 integra LS booster and mc for the abs removal?
and if you use RS mc you can use the RS brake lines?</TD></TR></TABLE>
pretty much. I have heard you can modify the RS lines to work with the GSR MS but I have never tried. The difference is the outlet locations on the MS is different between the RS and GSR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guymosiris &raquo;</TD></TR><TR><TD CLASS="quote">I would also like to know this. I'm removing my ABS in a GSR, but will use stainless braided lines for the brake lines. Does this mean I can keep my oem GSR MC/BB and just buy a prop valve? If so, it'll save me $100.</TD></TR></TABLE>
yes, I run the bigger GSR MS
This is a great info thread put together by Migs https://honda-tech.com/zero...age=1
jsnm
Jul 11, 2018 12:30 PM
TurbodTegSfaria
Sep 25, 2009 09:51 AM
glazedham42
Feb 27, 2006 06:04 AM
