bad tranny.....??ls diff and gsr diff interchangeable..
Old Feb 25, 2005 | 08:00 AM
mr. vang's Avatar
Default bad tranny.....??ls diff and gsr diff interchangeable..
picked up a ls trans with a bad diff..i got a gsr diff and wwas wondering if its interchangeable..thanks guys
Old Feb 25, 2005 | 09:06 AM
Kendall's Avatar
The diff is interchangable as long as you also have the final drive for the GSR diff.
Old Feb 25, 2005 | 09:40 AM
PupaScoopa's Avatar
Default Re: (Kendall)
I hear you should match hydro-hydro or cable-cable transmissions. You'll need to properly shim the diff and output shaft once you do the swap.
Old Feb 25, 2005 | 03:50 PM
mr. vang's Avatar
i have a gsr diff but no gear.. ..where can i find one for cheap....besides honda dealer...
Old Mar 1, 2005 | 05:40 PM
jasyatz's Avatar
Default Re: (jdm_whore)
B16/GSR diff will work fine, but you'll need to swap the counter shafts to do it (with the 4.40) final drive..
If you want to swap just the diffs, the GSR won't work since the LS final drive is 4.26 vs the GSR 4.40. The LS ring gear MAY bolt up to a B16 diff, but I'm not sure..
They appear to be the same internal diamter, but I don't have an LS ring gear to test fit on the B16 diff I have..
If you already bought/have the GSR ring gear and want to sell it, let me know..
Jeff
Old Mar 1, 2005 | 07:59 PM
mr. vang's Avatar
Default Re: (jasyatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasyatz &raquo;</TD></TR><TR><TD CLASS="quote">B16/GSR diff will work fine, but you'll need to swap the counter shafts to do it (with the 4.40) final drive..
Jeff</TD></TR></TABLE>
if i had the gsr ring gear i would of used it..but i dont..just the diff..
Old Mar 1, 2005 | 08:17 PM
Kendall's Avatar
The B16 uses the same ring gear bolt pattern as the LS and it won't fit on a GSR diff. Have you considered going to the JDM 4.785 final drive? It's not really all that expensive, plus your tranny's apart anyway.
LS94tegra
Transmission & Drivetrain
Apr 16, 2010 10:08 PM
scspeed
Feb 2, 2010 09:19 PM
ground_shaking
Nov 11, 2009 06:20 AM
sj-performance
Nov 9, 2009 02:35 PM
Lscivichatch92
14
Oct 11, 2004 04:25 PM
