help my car wont start (not starter)
Old Feb 25, 2005 | 07:50 AM
HANABLE's Avatar
Default help my car wont start (not starter)
for the past few weeks my car wont start, but i can push start it. i thought it was the starter but when i bought a new one, it clicked a few time like the gears werent linded up, so i pushed it a little bit and when i tried again it acted the same way......all the lights turn on and when i turn the key nothing........please help. any advice would be great.
hanable
Old Feb 25, 2005 | 10:01 AM
Grodzman's Avatar
No cranking at all? I had that problem less than a week ago, and it was my starter.
Got a new one and it worked fine.
New Honda starters come with a one year warranty, I say replace it again and do it for free this time, you might have gotten a melon like I did.
Within a few weeks the car wouldn't hot start.
Old Feb 25, 2005 | 11:08 PM
HANABLE's Avatar
Default Re: (Grodzman)
thank you for the input. could it be the fly wheel or the battery not being charged all the way? **** man i dont know im stumped. ill try it and hope for the best....wish me luck...
H.
Old Feb 26, 2005 | 06:13 AM
jakeiscool's Avatar
Banned
Default Re: help my car wont start (HANABLE)
I had that same problem for a while, I guess I still have it becuase I havent fixed it, I think it might be a bad ground or the flywheel.
Old Feb 26, 2005 | 10:27 AM
HANABLE's Avatar
Default Re: help my car wont start (JakeIsCool)
that might be it ill look in to it. thank you for the advice..
H.
Old Feb 26, 2005 | 10:44 AM
BlazeTeck2000's Avatar
you can also check your fuse or see if your radio turns off when you put it to loud if it does that means your batt is going bad or you may need to clean the heads
Old Feb 26, 2005 | 11:25 AM
TOAB's Avatar
Your battery is at full charge right? Just thought I'd ask.
Old Feb 26, 2005 | 11:31 AM
HANABLE's Avatar
Default Re: help my car wont start (BlazeTeck2000)
i have a marine deep cycle battery and it seems to be fine. but iam charging it as we speek.
thanks H.
Old Feb 26, 2005 | 11:34 AM
HANABLE's Avatar
Default Re: (TOAB)
does that matter that much if every light comes on bright as hell.?...
i dont know thats why i ask?
thanks
H.
Old Feb 26, 2005 | 11:58 AM
Default Re: (HANABLE)
yea if its brite thats a good sign. did you check if they installed the starter right ? when you put the batt back on make sure that its on tight . when you begin to start it does the lights on the dash come on and go off when tring to start ?
Old Feb 26, 2005 | 12:55 PM
HANABLE's Avatar
Default Re: (BlazeTeck2000)
i work on my car my self and i know it was on right and tight.and yes the light do that .
H
Old Feb 26, 2005 | 12:57 PM
hondadude's Avatar
do you have aftermarket battery terminals, they can corrode inside the cable clamp. it really sounds like you have weak current. Check all the cables and grounds.
Old Feb 27, 2005 | 03:43 AM
HANABLE's Avatar
Default Re: help my car wont start (hondadude)
yes i just found out that my **** ing battery was noyt holding a chaRGE so .... well you know thanks to all.
ill keep you up dated, thanks for your intrest.
H
Old Feb 27, 2005 | 05:40 PM
HANABLE's Avatar
THANKS TO ALL! THE PROBLEM IS SOLVED.....
THE ANSWER GOES TO HONDADUDE HAHAHAHAHA AND THANKS FOR ALL THE OTHER INPUT GUYS.. I COUNLDNT OF DONE IT WITH OUT YOU...
YES
HANABLE
nighttrain33
10
Feb 25, 2007 08:10 PM
andyep3
Jun 1, 2006 06:42 AM
lowblazin
Nov 25, 2003 10:00 AM
Brett-Pac
Sep 7, 2003 04:51 PM
