Field SFC with b16a and CRX wiring woes..
Old Feb 25, 2005 | 07:44 AM
Outsane's Avatar
Default Field SFC with b16a and CRX wiring woes..
Installing a Fields SFC on a 88 CRX SI with b16a and PR3 ecu
I have been using both
http://www.integra.orcon.net.nz/fieldsfc
and
http://asia.vtec.net/beystock/....html
i
The sensor line is the only one I dont' have connected, when I did I threw 2 codes, 21 and 22.
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
Any ideas
Old Feb 25, 2005 | 11:53 AM
Outsane's Avatar
Default Re: Field SFC with b16a and CRX wiring woes.. (Outsane)
bump
Old Feb 25, 2005 | 02:14 PM
PaImportTuner's Avatar
well 2 wires go to Fields SFC and 2 come out and go to ECU the SFC becomes the "middle man". and alters the ECUs vtec and fuel. I'm sure you know this, being knowledgable i see you post,your sponsered and a crew cheif.. smart enough.
so make sure you got the 2 correctly tapped to SFC and going to ECU. make sure the 2 wires aren't switched around going into SFC or out. and if that fails YOU HAVE A BAD SFC. If you just bought it that's prolly why the person sold it.
still would be good to control fuel for like a nonvtec junkyard turbo setup, if it still works properly.for like $50
Old Mar 1, 2005 | 09:16 AM
Outsane's Avatar
Default Re: Field SFC with b16a and CRX wiring woes.. (PaImportTuner)
It was all my fault I was wirng it up to the wrong white wire..
in my haste..
it works great now..well as far as the fields goes..
the car looses power when v-tec kicks in, nice huh..
more to figure out..
toolegit86
16
Oct 13, 2010 07:55 PM
Outsane
Feb 25, 2005 11:52 AM
JinDIESEL
Sep 28, 2004 05:46 AM
B18C1_CRX
Apr 27, 2004 09:24 PM
shaddr3
Apr 12, 2004 12:33 PM
