help with stuck bolt
Old Feb 25, 2005 | 07:44 AM
Ragecloak's Avatar
Default help with stuck bolt
Taking t he heat shield off over my exhaust manifold. Took the top bolt off without using anything like wd 40 (actually the stuff i'm using is in a yellow bottle and called some kind of catalyst....supposedly way better than wd 40). Well the bolt got stuck in the wrench, so i had to hold it with whatever I could find, and beat it out with a screwdriver. So on the next bolt I used the petetrating lubricant, and the same thing happened! There's gotta be an easier way to take out and retrieve a bolt!
Old Feb 25, 2005 | 07:51 AM
.William J. Clinton.'s Avatar
Default Re: help with stuck bolt (Ragecloak)
So the bolt is stuck in the wrench? Thats a bitch man, you sure your using the correct size socket?
Old Feb 25, 2005 | 07:54 AM
EKDreamin's Avatar
More then likely the rust on the bolt has caused it to swell somewhat so although the wrench you are using is more then likely the right size, the rust is causing you some problems. You might consider taking a wire brush to the bolt before attempting to take it out. This will give you a cleaner surface and a more accurate sizing. Good luck.
-Scott
DCRB
13
Mar 23, 2010 09:47 AM
thrty8street
34
Jun 28, 2004 07:06 AM
GroundZer0
Mar 12, 2004 07:06 AM
is3oo
Oct 4, 2003 01:48 PM
hellas
Jan 21, 2003 12:33 PM
