have a few questions?
Old Feb 25, 2005 | 06:20 AM
ALL MOTOR EF8's Avatar
Default have a few questions?
Will coilover from a 92 civic work on a 90 si rex? How bout the shocks?
If I put a jdm sir cluster in my rex how do I get it to work?
Would jdm amber coners fit on a usdm front?
Old Feb 25, 2005 | 06:42 AM
crxnj's Avatar
Default Re: have a few questions? (ALL MOTOR EF8)
The coils will fit..
88-00 civic/integra/del sol springs will all fit..Spring rate might be off but they'll technically fit..
You can use the front shocks but will need to use 92-95 civic forks..
I dont know if the rear shocks will fit though because I've never tried it..
Old Feb 25, 2005 | 06:03 PM
Default Re: have a few questions? (Mr.speaker)
Help
Old Feb 26, 2005 | 03:08 AM
Help.
Old Feb 26, 2005 | 05:02 AM
LSVTEC 91 Civic's Avatar
Banned
JDM Corners will fit... you'll need a VSS for that JDM Gauge cluster. I don't know about the shocks/springs. Maybe you can check with different companys to find out if they have the same part number or not for the EFs and EGs.
Old Feb 26, 2005 | 06:07 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR EF8 &raquo;</TD></TR><TR><TD CLASS="quote">Will coilover from a 92 civic work on a 90 si rex? How bout the shocks?
Would jdm amber coners fit on a usdm front?</TD></TR></TABLE>
Coilovers will work.
Struts will work with the use of EG front forks.
JDM cluster needs VSS, try and find a UK one thats cable to make it easy.
"JDM" EF corners are CLEAR and single bulbs but they will work.
Old Feb 26, 2005 | 06:16 AM
Default Re: have a few questions? (kid-honda)
I know the front shocks will fit but what about the rear? I gonna do a b20 vtec wit a b16 hydro tranny can I use that vss?
Old Feb 26, 2005 | 07:15 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR EF8 &raquo;</TD></TR><TR><TD CLASS="quote">I know the front shocks will fit but what about the rear? I gonna do a b20 vtec wit a b16 hydro tranny can I use that vss?</TD></TR></TABLE>
I said they will work
As far as I know any VSS will work.
Mikege82012
Honda Fit
Feb 29, 2016 07:24 PM
jdm21
12
Feb 21, 2009 04:03 PM
B18 CYA
Aug 16, 2005 01:25 PM
randyklimek
Apr 11, 2004 06:03 PM
Xumarius
Jul 27, 2003 10:48 AM
