Removing Power Steering Belt.
Old Feb 25, 2005 | 06:03 AM
luderollin's Avatar
Default Removing Power Steering Belt.
I got the nut off of my crankshaft pulley (trying to get into the timing belt area) What do i need to do to get the timing belt off or what is the easiest way to get it off i was trying to loosen the alternator by the screws on the bottom but i cant tell which ones it would be and my repair manual is at a buddys forwhile anyone have any ideas thanks!
Old Feb 25, 2005 | 07:55 AM
accord-lude's Avatar
Default Re: Removing Power Steering Belt. (luderollin)
If you trying to remove the power steering belt off. you dont have to take the crank pulley out. all you do is unscrew the adjustiable screw that holds the power steering pump and once it's lose take out the belt. easy as that.
Old Feb 25, 2005 | 12:07 PM
PrettyLude's Avatar
leave the crank pulley alone
motegicivic
Nov 25, 2011 03:50 PM
tl44
Jan 31, 2011 05:05 PM
porter
29
Jan 31, 2007 09:31 AM
Scharged00GsR
Jul 12, 2004 05:58 AM
G2Integrity
Feb 26, 2002 04:31 PM
