had a quick look....DIY AC removal.....any here ?
Old Feb 25, 2005 | 03:50 AM
bennjamin@ozhonda.com's Avatar
Default had a quick look....DIY AC removal.....any here ?
H guys . . .
I have been wanting to remove my AC system for a while now out oif my 1992 EG5 hatch.
Are there any good step by step online guides to fully remove both compressor , condensor , cooler box etc and ofcourse cover everything up ?!?
Thanks again Ben
Old Feb 25, 2005 | 08:03 AM
BeavisB16's Avatar
Default Re: had a quick look....DIY AC removal.....any here ? (bennjamin@ozhonda.com)
start unscrewing everything that connects to the A/C compressor. It's pretty easy.
Old Feb 25, 2005 | 12:37 PM
Default Re: had a quick look....DIY AC removal.....any here ? (BeavisB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeavisB16 &raquo;</TD></TR><TR><TD CLASS="quote">start unscrewing everything that connects to the A/C compressor. It's pretty easy.</TD></TR></TABLE>
Thats not my worry- its removing the freon , and fixing up the cooler box etc for the long run as oneday i do want to sell the car with the AC , so i woudl want to attempt this as professionally as I can.
Any guides or advice ?!
Old Feb 25, 2005 | 01:32 PM
TheIntegraGuy's Avatar
When I did my swap, I didn't care about the freon*. I just unscrewed everything, illegally expose it to the atmosphere, chill in the house for a good 20 minutes, came back and removed the whole system.
Old Feb 25, 2005 | 01:52 PM
NA95d16z6's Avatar
Default Re: (TheIntegraGuy)
make sure when u evac the AC system you jam a screw driver into both recepticles. wrap a bunch of shop rags around the screwdrivers when you do this. and cover anything you dont want stained a flourescent green.
and im pretty sure its not freon in your car. prolly R-134. i dunno when honda stoppped using freon, so actually evaccing the system isnt bad for the atmosphere, its just illegal.
MAKE SURE NOBODY SEES YOU EVAC THE SYSTEM INTO THE AIR.
you could get hit with some hefty fines if you are spotted by any one that cares.
Old Feb 25, 2005 | 02:00 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: (NA_95d16z6)
Wait, I thought the whole point of the switch to r-134a was the fact that It <U>wasn't </U> harmful to the atmosphere. So what would make venting it to the atmosphere illegal?
Old Feb 25, 2005 | 02:14 PM
Lucian0's Avatar
From what I've read, R-134 is environmentally safe and CFC free. So, that wouldn't make it harmful.
Of course, if you use freon in the system, its quite illegal and harmful to the environment.
Old Feb 25, 2005 | 02:30 PM
NA95d16z6's Avatar
Default Re: (HalfAnP)
well freon isnt completely illegal, it is illegal in automobile use.
my friend works in HVAC and said that freon (R-12) is still used but not as widespread. u have to have permits and **** to use it. but venting either R-12 or R-134 into the atmosphere is still illegal. theres just govt regs about it.
Old Feb 25, 2005 | 02:43 PM
MASTRCHANN's Avatar
whatever it is, be EXTREMELY careful when your unbolting anything. I made the mistake of just going at it with my tools and the compressor blew up in my face-&gt; sucks REALLY bad.
Old Feb 25, 2005 | 02:50 PM
sohcvtec1995's Avatar
Default Re: (MASTRCHANN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MASTRCHANN &raquo;</TD></TR><TR><TD CLASS="quote">whatever it is, be EXTREMELY careful when your unbolting anything. I made the mistake of just going at it with my tools and the compressor blew up in my face-&gt; sucks REALLY bad. </TD></TR></TABLE>
omg how the hell diod that happen? its like a couple blots, a belt, and like 2 brackets, a couple of lines. I didnt know that honda install a compressor bomb on them.
But yea its easy. the hardest part is the interior crap. you hae to rip the dash out to completly remove everything.
99fbpem1
Oct 13, 2007 05:52 PM
mtownek9
Oct 9, 2007 06:30 PM
661rex89si
14
Oct 27, 2006 04:03 PM
not2fast
Sep 4, 2006 10:28 AM
type Gendy
Feb 26, 2004 12:31 PM
