205-40-16 Azenis on a 16X6.5 Rim with +50mm offset.
Will a 205-40-16 Azenis on a 16X6.5 Rim with +50mm offset fit on my 2000CX hatchcrapper? I don't mean just barely fitting either.. I don't want any rubbing.
Stock height.
Stock height.
you should be fine, on my eg i run 215/45/16 azenies on mugen mf8's with a 52 off set and i have no rubbing issues and the rear quarters are not even rolled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twisted sister »</TD></TR><TR><TD CLASS="quote">you should be fine, on my eg i run 215/45/16 azenies on mugen mf8's with a 52 off set and i have no rubbing issues and the rear quarters are not even rolled.</TD></TR></TABLE>
and you are sexy.
and you are sexy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_da_car »</TD></TR><TR><TD CLASS="quote">205 on a 6.5 is fine... with the 50 offset pretty much the same clearance as stock...</TD></TR></TABLE>
i am sure you can put it on the wheel, but why? its the wrong fitment......
the tire is going to be pulled in at the edges...reducing contact patch
i wasn't arguing the wheels,, but the tire fitment on the wheels
i've ran 205s on a 6.5 rim before... no problems.... but i do agree when i ran 195/60 on my 14 steels... u can tell that there was high sidewall stress... so i took it easy on those tire/rim combo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_da_car »</TD></TR><TR><TD CLASS="quote">i've ran 205s on a 6.5 rim before... no problems.... but i do agree when i ran 195/60 on my 14 steels... u can tell that there was high sidewall stress... so i took it easy on those tire/rim combo... </TD></TR></TABLE>
What size wheel and what was the aspect ratio of the tire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">azenis comes in 205/40/16? are you sure? i bought paradas cuz they were one of the few tires for 16's
the new ones do, at least. http://www.falkentire.com/upda...s.htm
Aug 24, 2004 03:20 PM
01PYTypeR#1140
Feb 17, 2004 04:27 AM
