d15b turbo with stock internal
Old Feb 24, 2005 | 11:27 PM
nxstrikerxn's Avatar
Default d15b turbo with stock internal
i was wondering if i have a jdm d15b wats the max psi n also reliable that i can boost in my car with stock internal cuz i might be gettin turbo but iono if it is reliable den NA cuz my car is pretty quick comparing to ex n si hatch cuz my clutch is worn out n i can still beat them easily motor to motor
Old Feb 25, 2005 | 02:03 AM
skip.two's Avatar
Default Re: d15b turbo with stock internal (nxstrikerxn)
all depends on the kit, and the tuning. you may want to get a new clutch kit as well.
Old Feb 25, 2005 | 05:38 AM
civicminded92's Avatar
Default Re: d15b turbo with stock internal (jL iLLuZiOnz 9)
I've seen a well tuned stock bottom end D15B7 using a 14b set a 8psi and, with TUNING, is getting 195 whp. You should be able to shoot higher since you have bigger rods/journals if you have the JDM D15B - should be comparable to the D16.
Keep in mind that the boost number isn't the only factor in making reliable power - please get the A/F tuned correctly on a dyno!
An you will need a new clutch if it's slipping with stock power levels....
My advice is to read about turbocharging until your eyes bleed, then sleep and get up and read some more. If you jump into this thinking "Hey, 8psi is safe and reliable," but don't know the CONDITIONS at which it is safe and reliable, you will have a destroyed engine in no time flat.
Summary:
Read more
Old Feb 25, 2005 | 05:40 AM
slipstream2005's Avatar
well usually with stock internals you can run around 8 lbs daily and can be a reliable car to run...but yeah it does also depend on your setup
Old Feb 25, 2005 | 06:50 AM
Chillin94hatch's Avatar
Default Re: d15b turbo with stock internal (slipstream2005)
If tuned properly 8-9 psi daily...a good fuel managment setup is the key
Old Feb 25, 2005 | 06:56 AM
4drmadness's Avatar
defnitely have it tuned right on a dyno and there's no reason the 8-9lb mark couldn't be achieved for daily driving.
Good luck w/ that...
Old Feb 25, 2005 | 07:49 AM
Slammd Sol's Avatar
I'm running 10-12psi on my d15b. Use Uberdata with a good, fairly conservative tune and you'll be alright.
Old Feb 25, 2005 | 10:08 PM
Default Re: (Slammd Sol)
hey since ur one of my fellow d15b where did u go to get ur turbo tune n how much is it
Old Feb 26, 2005 | 11:18 PM
i just did a research that i cant upgrade my internal so i was wondering if i go turbo wat can i upgrade beside vailtrain n springs??? thnx for the feed back guys
bump for the replies
Old Feb 26, 2005 | 11:28 PM
95excoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxstrikerxn &raquo;</TD></TR><TR><TD CLASS="quote">i just did a research that i cant upgrade my internal so i was wondering if i go turbo wat can i upgrade beside vailtrain n springs??? thnx for the feed back guys
bump for the replies </TD></TR></TABLE>
You really dont have to touch the head. I mean you could, but it would be a waste in my opinion. Low compression pistons and strong rods are what you want for more boost. You will need a stronger clutch too. Mine stopped working at ~7-8psi in high rpm's, it just spun and it was a fairly new clutch too. Just remember tuning is key. Get bigger injectors and go get it tuned and you could make some nice numbers on a stock engine.
Oh and an LSD is always a nice choice to help with traction
Old Feb 27, 2005 | 07:24 AM
Default Re: d15b turbo with stock internal (95excoupe)
well since u said to upgrade piston n robs do u know ani place that sell it n do u know wat clutch that grips hard like stage 2 or 3 but the pedal is like si or gsr not that stiffa friend of my has it but i didnt ask for the name
Old Feb 27, 2005 | 07:30 AM
Soccerking3000's Avatar
i dont understand how people say they are running 10 psi could be related to someone saying they are running 8 psi. PSI has nothing to do with whp, you could have a monster turbo running 5 psi and a small 13g running 18psi and you'll have the same power. so if you say ur running so and so psi, please say what turbo you have otherwise it means nothing
hotrex
Apr 16, 2005 08:56 AM
94civicspeed
13
Mar 25, 2005 12:05 AM
ShuaiGuy
Jul 13, 2004 06:30 PM
donnie B
Dec 1, 2002 08:49 PM
GettaluvR
Nov 24, 2002 04:53 PM
