Trans comes out of 2nd gear
When i make a righthand turn and the trans is in 2nd gear it comes out of gear by its self. My mounts are ok, i have Hasport mounts but i have has a problem with the rear one before. Im out of clues as to what the problem is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">sounds liek a shift linkage problem, is it a choppped cut or name brand??</TD></TR></TABLE> nope its a JDM ef9 shifter, the gold one.maybe the bushings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burlyirishdude »</TD></TR><TR><TD CLASS="quote">change your MT fluid....
I second that
</TD></TR></TABLE>I second that
have you had any problems with it before? my car had the same prob but in first, my shift fork was broken, try to change the fluid and check the linkage but it might be alittle more serious
I'm useing G.M. sycromesh in the trans. I hope its not the syncros cause its a Y1 trans with a lsd. And the parts are hard to find. Not that longago the saddle the holds the mount on the trans side broke the spot welds and i had a new piece welded in and i mad sure theat it whent in the exact same spot.
rizq777
Sep 25, 2004 07:57 AM
