integra dash swap question
Old Feb 24, 2005 | 09:58 PM
hybridracer504's Avatar
Default integra dash swap question
i juss finished my dash swap and i was wondering if anyone knows how to rewire the hazard switch, defroster, and dimmer switch...
Old Feb 25, 2005 | 10:12 PM
Default Re: integra dash swap question (hybridracer504)
help
Old Mar 8, 2005 | 10:09 PM
ill_imports's Avatar
if you havnt figured it out yet, grab a multimeter and check the pinout and compare to your stock switches
this will solve any wiring problems guaranteed!
Old Mar 17, 2005 | 10:30 PM
PDM's Avatar
PDM
Default Re: integra dash swap question (ill_imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_imports &raquo;</TD></TR><TR><TD CLASS="quote">if you havnt figured it out yet, grab a multimeter and check the pinout and compare to your stock switches
this will solve any wiring problems guaranteed!</TD></TR></TABLE>
Thats not going to help.
Everything the poster described is connected using a separate harness. Theres a harness JUST for your climate controls, hazards and so on. You'll need to find one from an integra. Luckily these are plug and play and dont need rewiring.
Old Mar 21, 2005 | 07:15 PM
10K4U's Avatar
hopefully this will help you https://honda-tech.com/zero...opics look at my post about the wiring.
Old Mar 21, 2005 | 10:46 PM
Soccer10's Avatar
Default Re: integra dash swap question (10K4U)
What car did you convert it into, was it hard?
Old Jul 2, 2005 | 08:34 AM
Sean Juan's Avatar
Default Re: integra dash swap question (Soccer10)
bump for the same answer.
no one on honda-tech has posted a definite answer.
esteps
Sep 17, 2004 04:30 PM
shivic
Apr 26, 2004 03:08 PM
97blackcoupe
Apr 18, 2004 04:20 PM
