b16 stroked stock what to use(searched)
like the title says guys i am thinkign about stroking my b16 cuz i will get the labor for cheap i know i have to get a crank and rods but what else and which ones? also or would it be better to just get a gsr shortblock? thanks i also searched but i didnt really get anything back i just got like can i stoke and boost?
Toda's B16A stroker kit. Comes with a 87.2 mm crank (GSR crank), forged pistons, rings, rods, and thinner head gasket. Rod stroke ratio comes out to being 1.54 which is about the same as that of a B18B.
anyone have liek aruff idea on how much would it be if i find everythign cheap or would it be cheaper to go with a gsr a lovcal guy on h-t is sellign me the short block for 500
id say use a b20/b18a/b crank & rod combo and get the tech43 custom piston that moves the wrist pin location higher to allow of for proper piston to deck clearances. itll produce ls/vtec torque numbers due to the same stroke & same r/s ratio. and the best part, is you can say "dont worry its only a 1.6"
btw hope you dont mind me asking, but if you dont get the gsr block, mind telling me whose selling it so i can pick it up
hey gutted ill pm it to you tomarow ill about to go to sleep iam kind of tight with money right now they tried stealing my car again **** theives but will that be cheaper then 500 for parts if i get them used??
depends on how much you can get LS crank & rods. some guy on the chicago classifieds is selling rods + stock pistons for $20 i think. cranks range from $50-$150. the most expensive part would be tech 43's custom forged pistons. i think its around $500. then you have to toss in a set of new bearings, arp rod bolts if your revving past 8100 rpm, hone or bore. so total its kind of pricey but this block is brand new compared to the used on.
BTW thanks for PMing me the guys name. you going to the HT meet on the 6th?
hey bro just email tech43 at steve@tech43.com with all ur questions and he will be able to help u and lead you to the right direction. He knows his **** and great guy
. Do it right the first time.
white4doorsi
Mar 15, 2008 05:35 PM
