some serious questions bout jdm b16a
Old Feb 24, 2005 | 07:38 PM
shownogo's Avatar
Default some serious questions bout jdm b16a
im buying a jdm b16a block. does anyone know what vehicle they come out of.
im going to need a head, alternator, timing gears and tensinor, valve cover, head bolts and just about everything. what trans should i use, what ecu and what to do for wiring harness. im new to the import world but want to build my own motor for my 89' honda crx any help will be greatly appreciated. thanks everyone
Old Feb 24, 2005 | 07:56 PM
doublethink's Avatar
Default Re: some serious questions bout jdm b16a (shownogo)
cars:
CRX SiR
Integra XSi
ecu you need:
PR3 or PW0
tranny:
y1, ys1, s1 OR j1
the rest can be had form autozone or pep boys, ask for 1990 integra.
heres a list of what cars to get the parts from for a b16a:
https://honda-tech.com/zerothread?id=1024595
why didnt you just buy a swap, its going to cost more this way. good luck though.
Old Feb 24, 2005 | 09:11 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shownogo &raquo;</TD></TR><TR><TD CLASS="quote">im buying a jdm b16a block. does anyone know what vehicle they come out of.
im going to need a head, alternator, timing gears and tensinor, valve cover, head bolts and just about everything. what trans should i use, what ecu and what to do for wiring harness. im new to the import world but want to build my own motor for my 89' honda crx any help will be greatly appreciated. thanks everyone</TD></TR></TABLE>
Don't do it.
The amount of work, time, money, and effort in need to find purchase and assemble all those parts in "not" worth it. As Doublethink has stated, your much better off buying a complete assembled swap, with the only parts needed for a decent setup would be axels, mount kit, shift linkage, new timng belt and clutch.
You'll be much better off in the long run.
Old Feb 24, 2005 | 09:35 PM
FairlightRacing's Avatar
Don't assembly your own motor from parts. Don't outer just the "long block." Don't order just the engine/tranny/ECU. Do go to hmotorsonline.com. Do order the JDM B16A1 "complete change over." Do thank me afterward for my advice.
Seriously, do what I said and nothing else. Why? Because you will save hundreds and hundreds on parts. You will save so much time in not having to source all the parts and dealing with all those different sellers. You won't swap an engine in to your car only to have it not start because one idiot (out of 30) sold you crap.
Believe me, I'm not talking from hearsy. I was like you and wanted to order the cheapest parts as singles from all over. But in the end I did what I said above and am glad I did. I ended up getting a super clean swap from hmotorsonline.com that included axles ($200 saved), shift linkage ($150 saved), rear tranny bracket ($50 saved), and so much time (priceless).
hmotorsonline.com
any thing else
Old Feb 24, 2005 | 09:43 PM
hahagasdcrx's Avatar
Default Re: some serious questions bout jdm b16a (FairlightRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FairlightRacing &raquo;</TD></TR><TR><TD CLASS="quote">Don't assembly your own motor from parts. Don't outer just the "long block." Don't order just the engine/tranny/ECU. Do go to hmotorsonline.com. Do order the JDM B16A1 "complete change over." Do thank me afterward for my advice.
hmotorsonline.com
any thing else </TD></TR></TABLE>
Very well put....
Jason Nucom
Nov 27, 2012 08:26 AM
BlackHXCoupe
Jul 21, 2006 12:48 PM
BlackHXCoupe
Northern California (Sales)
11
Jul 19, 2006 09:43 PM
lsvtec79
Mar 28, 2006 11:15 AM
b16a27
Nov 1, 2004 12:50 PM
