is it safe to run ctr pistons w/ new oem stock headgasket?
i have a 94 gsr and i just bought some new ctr pistons for the motor! i have a new oem gasket kit! would it be safe to run the car w/ stock head gasket? (im also running the hondata program)
ur gonna want to get a thicker headgasket.. u do know that ctr's in a gsr will give u like 13.2 comp with a stock headgasket...... check out the sticky at the top of the this forum... not sure what thickness gasket u should run.........but i'd look into it
if i were you id get a thiker one if you didnt want 13 or above compression...or a b16 head or somthing but you can use it yes
HamiltonRex
17
Feb 15, 2005 08:49 AM
Dohcvtec59
Oct 15, 2004 04:44 AM
