my battery dies after 1 day without use.
Old Feb 24, 2005 | 02:37 PM
crxh22project's Avatar
Default my battery dies after 1 day without use.
I recently did a B16 swap on a 90dx and when i turn on the engine for more thatn 2 days the battery dies. i moved the battery to the back. thats probably all i have done with electrical, i also noticed the starter solenoid no engaging the other day when it i fired it, i only hear a the starter motor moving but no the engaging with the flywheel,.
i dont have my stereo on whatsoever, the battery is brand new Exide orbital.
any suggestions?
Old Feb 24, 2005 | 02:39 PM
kulangot's Avatar
Default Re: my battery dies after 1 day without use. (crxh22project)
something is draining your battery..
Old Feb 24, 2005 | 03:00 PM
Gumbey75's Avatar
Default Re: my battery dies after 1 day without use. (sirq2u)
get your alternator checked out. its draining your battery
Old Feb 24, 2005 | 03:04 PM
j_max420's Avatar
sounds like your alternator isnt charging and/or you have a draw, try doing a parasitic load test, and check and see if the alternator is charging by taking a meter and seeing if the alternator is putting out 12 volts
Old Feb 24, 2005 | 05:18 PM
Default Re: my battery dies after 1 day without use. (j_max420)
i think the alternator works because it charges the battery when i leave it on, the only electrical modifications are cd player amp and battery mounted on the back.
i can turn back on after a jump start.
I disconected the L sensors on the doors you guys think that drains my battery even though i dont have a dome light working?
disposable
Jun 26, 2008 08:02 PM
hondaracer13
Jul 19, 2007 07:45 PM
idewson
Aug 31, 2006 11:45 AM
ITR-00-1457
Apr 14, 2004 01:05 PM
Hung
Apr 20, 2002 02:58 PM
