oil on spark plugs....
Old Feb 24, 2005 | 02:11 PM
diewX3's Avatar
Default oil on spark plugs....
Just took my spark plugs to check them out. There's slight oil above the gasket where the plug meets the head. Is there a gasket I need to replace to prevent oil on the plugs? It's on all 4 of the plugs btw.
Old Feb 24, 2005 | 02:14 PM
98TypeSH's Avatar
Default Re: oil on spark plugs.... (diewX3)
If you pull the valvecover off there are 4 little o rings that prevent oil from getting to where the spark plugs are. I believe i have 4 extra brand new ones at my house. Anyway, go to the dealer and tell them what u want.
Part number: 12342-PG6-000 almost 2 bucks each.
Old Feb 24, 2005 | 02:33 PM
diewX3's Avatar
Default Re: oil on spark plugs.... (98TypeSH)
Is it #4 in this picture?
I'd have to remove the valve cover to get to these correct? Might as well change the valve cover gasket as well
Old Feb 24, 2005 | 02:34 PM
98TypeSH's Avatar
Thats it. Numero 4.
may as well if u want. ^_^ Usally you can just honda-bond the cam humps. No need to replace the gasket unless A. you feel like it B. its torn or ripped and is leaking oil all over the place.
Old Feb 24, 2005 | 02:35 PM
SUB-0 H23's Avatar
yes it is #4
Old Feb 24, 2005 | 03:33 PM
diewX3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Usally you can just honda-bond the cam humps..</TD></TR></TABLE>Where do you get Hondabond at? I asked the parts guy and he had no clue what I was talking about for my oil pan and sold me a gasket
Old Feb 24, 2005 | 03:50 PM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewX3 &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get Hondabond at? I asked the parts guy and he had no clue what I was talking about for my oil pan and sold me a gasket </TD></TR></TABLE>
They sold you an oil pan gasket? For your 97 Lude? Return it and throw it at them with a passion. 5th gen ludes dont use rubber gaskets for the oil pan. You either use Honda Bond (Pretty Expensive but the best stuff) or an equal quality liquid gasket sealer. If the *** sprinkels at the dealer dont know what Honda Bond is, they shouldnt even be working there. If your not in a hurry, I suggest you buy it from Slhondaparts.com, its $12 for a small tube. The dealer will charge you alot more.
Honda Bond Part No. : 08718-0001
Dealerships are so dumb...
Old Feb 24, 2005 | 03:58 PM
diewX3's Avatar
thnx for the advice guys, i order Hondabond from SLHondaparts. How much do I get for 1 tube?
Old Feb 24, 2005 | 04:01 PM
98TypeSH's Avatar
Default Re: (diewX3)
a tube of honda-bond goes a long way. i get like 30% off at my dealer so im good to go
Old Feb 24, 2005 | 04:08 PM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diewX3 &raquo;</TD></TR><TR><TD CLASS="quote">thnx for the advice guys, i order Hondabond from SLHondaparts. How much do I get for 1 tube? </TD></TR></TABLE>
I have done my oil pan twice, and rear main seal cover twice. Adding a decent amount on all four applications and i still have enough for one more oil pan change. There is a small half-moon gasket that goes on the flywheel side of the oil pan, you should change that also since your gonna have the pan off. I think thats what the dealeship might have thought you were talking about.
LandeZak
22
Aug 27, 2014 08:41 PM
BlueRex1020
Feb 8, 2007 09:17 PM
peAches yO
Oct 23, 2005 06:17 PM
1.8Tea
Aug 27, 2004 07:54 PM
ebelp
Sep 7, 2002 08:29 PM
