Good RPM take OFF?
Old Feb 24, 2005 | 02:08 PM
kriptik's Avatar
Default Good RPM take OFF?
wut rpm works for all of u guys? or is there something like a secret i dont know about a 5th gen SH, i have tried a bit of everything to perfect my take off, but i seem to be in a bit of a pickle here, all sarcasim and informational or opinions welcome, thanx
Old Feb 24, 2005 | 02:21 PM
The Phil's Avatar
Default Re: Good RPM take OFF? (kriptik)
take off, as in launching? I launch my 4th gen (H22) from about 3000, just because above that it doesn't do anything special.
Old Feb 24, 2005 | 02:23 PM
sniffthese's Avatar
Default Re: Good RPM take OFF? (xthephilx)
do ou mean just trying to drive normally or launch????? please specify
Old Feb 24, 2005 | 03:07 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kriptik &raquo;</TD></TR><TR><TD CLASS="quote">wut rpm works for all of u guys? or is there something like a secret i dont know about a 5th gen SH, i have tried a bit of everything to perfect my take off, but i seem to be in a bit of a pickle here, all sarcasim and informational or opinions welcome, thanx </TD></TR></TABLE>
Wait a second, are you racing or driving normally. I guess if you are driving normally, I can start at idle and work the accelerator with the clutch while I am letting out an my rpm's only travel up to 2k when the clutch is completely disengaged. If you are racing, feather the clutch at like 3000-3500rpm's. However, I have a 4th gen, but it shouldn't be all that different. Good luck!
Old Feb 24, 2005 | 03:31 PM
92hondalude's Avatar
Default Re: Good RPM take OFF? (maxvtec7500)
it all depends on what you have done to your car like clutch, differential, tires, and engine mods.
Old Feb 25, 2005 | 06:50 AM
kriptik's Avatar
Ok guys, i got intake exhaust and headers, thats it, and i mean launching for a race, sorry for the wrong wording, thanks!!!!
Old Feb 25, 2005 | 07:48 AM
L8ApexH22's Avatar
In Pro Solos, I'll launch my stock 4 gen. (with V710's) at about 4500. Jump off the clutch and mash the go-pedal at the same time, and I usually have minimal wheel-spin. YMMV.
Old Feb 25, 2005 | 08:51 AM
92silude's Avatar
I have a 4th gen and it's an h23, with stock wheels and tires it is dropped pretty low, and a few engine mods...if I go over 3 grand and drop it, and floor the gas, the tires just spin...so I tried launching at 1500-2000....and it has much better launch, with much less wheel spin
Old Feb 25, 2005 | 09:26 AM
The Phil's Avatar
Default Re: (92silude)
Don't do the ricer launch from redline, hondas aren't meant to do that. You'll just spin tires all over the place and it'll take forever to hook up.
Old Feb 25, 2005 | 09:49 AM
HTDragazn's Avatar
You should launch your car at 5k but don't drop the whole clutch feather it. Usually if you do good rpm stay at 5k and traction and vtec kicks in same time you just takes off
Old Feb 25, 2005 | 10:05 AM
The Phil's Avatar
Default Re: Good RPM take OFF? (HTDragazn)
Feathering the clutch at 5k'll make it die SO fast...just launch from 3k
Old Feb 25, 2005 | 02:51 PM
Dougs96SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTDragazn &raquo;</TD></TR><TR><TD CLASS="quote">You should launch your car at 5k but don't drop the whole clutch feather it. Usually if you do good rpm stay at 5k and traction and vtec kicks in same time you just takes off</TD></TR></TABLE>
You could do this if you want to replace a clutch every weekend. I dump the clutch around 3k and slam the gas. A little wheel spin, but it hooks up pretty quickly.
Old Feb 25, 2005 | 03:39 PM
matix's Avatar
Default Re: Good RPM take OFF? (Dougs96SI)
If you have a good clutch launch in vtec. My best 60' time was launching at 6k feathering the clutch.
Old Feb 25, 2005 | 03:48 PM
PnoyJeff's Avatar
Default Re: Good RPM take OFF? (matix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matix &raquo;</TD></TR><TR><TD CLASS="quote">If you have a good clutch launch in vtec. My best 60' time was launching at 6k feathering the clutch.</TD></TR></TABLE>
not trying to sound ignorant even though i probably still will but im kinda new at this car terminology...but what is/how do u feather the clutch
Old Feb 25, 2005 | 05:58 PM
01 LudeDude's Avatar
Default Re: Good RPM take OFF? (StreetINTEGRAtion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetINTEGRAtion &raquo;</TD></TR><TR><TD CLASS="quote">not trying to sound ignorant even though i probably still will but im kinda new at this car terminology...but what is/how do u feather the clutch</TD></TR></TABLE>
Means you let the clutch out slowly, not all at once (dumping). I won't do that to my daily driver, I don't need to be changing clutches every 6 months. I can kinda see the advantage of launching at 5-6K though, If you're good and can feather it out just below the threshold of wheel spin, you'll have peek power available for the duration of 1st gear. That is the theory right?
Old Feb 25, 2005 | 06:52 PM
matix's Avatar
Default Re: Good RPM take OFF? (01 LudeDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01 LudeDude &raquo;</TD></TR><TR><TD CLASS="quote">Means you let the clutch out slowly, not all at once (dumping). I won't do that to my daily driver, I don't need to be changing clutches every 6 months. I can kinda see the advantage of launching at 5-6K though, If you're good and can feather it out just below the threshold of wheel spin, you'll have peek power available for the duration of 1st gear. That is the theory right?</TD></TR></TABLE>
If you get good at it you should be able to see vtec the whole time in 1st gear. I dont launch my car the often but when i do i feather. Had my cm clutch in for about a year and 3 months now.
Old Feb 25, 2005 | 07:44 PM
bby6's Avatar
I <3 Rotas
i dunno about everyone else, but launching at about 2900 works perfect for me. no tire hop or anything. i'm all stock on toyo proxes, tell me how that works for you!
Old Feb 25, 2005 | 11:36 PM
Lude-acris's Avatar
i have a act stage 2 clutch, LSD tranny, and a jun flywheel. i rev it up to about 5k's, somewhere around there at least and feather the clutch off... it works bad *** once you know how to do it, and like HTDdragon said when you do it right you are pretty much in vtech the whole first gear.
Old Feb 25, 2005 | 11:37 PM
Lude-acris's Avatar
Default Re: Good RPM take OFF? (Lude-acris)
vtec haha
Old Feb 26, 2005 | 01:00 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude-acris &raquo;</TD></TR><TR><TD CLASS="quote">vtec haha</TD></TR></TABLE>
the ricer inside you slipped out,
and yes launch around 5-6k and feather, great 60ft times when you figure it out. before then you will just be making tons of smoke, so pratice
Old Feb 26, 2005 | 03:31 AM
DCbb6's Avatar
This is a step in the right direction, but at 5k you should slip the clutch and feather the throttle until you hook...it will hook fast...as mentioned by HTDragaznthing( vtec and traction will kick-in at the same time), basically what you're are doing is launching in vtec. it will take you about 3 runs to get it right....it makes a big difference...your 1/4 mile times will reflect.
Modified by DCbb6 at 4:48 AM 2/26/2005
Old Feb 26, 2005 | 10:09 AM
Lude-acris's Avatar
Default Re: Good RPM take OFF? (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
the ricer inside you slipped out, </TD></TR></TABLE>
you mean the stoned dumbass inside me slipped out
Old Feb 28, 2005 | 06:21 AM
RemerLex11's Avatar
Default Re: Good RPM take OFF? (sniffthese)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L8ApexH22 &raquo;</TD></TR><TR><TD CLASS="quote">In Pro Solos, I'll launch my stock 4 gen. (with V710's) at about 4500. Jump off the clutch and mash the go-pedal at the same time, and I usually have minimal wheel-spin. YMMV.</TD></TR></TABLE>
how the hell do you have minimal wheel-spin with a launch like that
Old Feb 28, 2005 | 09:12 AM
Lude-acris's Avatar
Default Re: Good RPM take OFF? (Matt5745767)
LSD+clutch
Old Feb 28, 2005 | 01:24 PM
ralpheezy's Avatar
i have an h23 with intake and exhaust and 17" wheels. if i launch above 3k it spins all through first and half through second but if i launch a little below 3k maybe 2 to 2.5k it won't spin for too long maybe until 5k or when i shift to second.
*edit* this is with dumping the clutch and stomping the gas.
