Sleeved B18C's -- Do you run oil squirters?
For those of you with sleeved B18C's, do you still run the factory oil squirters?
If so, did you have to machine them?
If not, do you wish you had them?
TIA
TIA
Well, I'm gonna run a Dart but it's also a sleeved block
and as I will also run forged CP pistons I have decided to block off the squirters.
I plan to make 8mm spacers and install them with the stock bolts instead of the squirters, so if I change my mind later on i can go back to squirting
The Jacko
Feb 26, 2005 07:33 PM
Turbocoupe97
Aug 14, 2004 05:34 PM
Turbocoupe97
Aug 14, 2004 03:30 PM
