ls tranny
Old Feb 24, 2005 | 05:29 AM
civic2slo's Avatar
Default ls tranny
I was wondering if my 99 si tranny diff. broke can I use a LS diff. Just remove the broken one and replace it without changing the ring gear (is it the same?). Are the LS syncros/gears? interchangable with the Si's? what would I have to do to switch the syncros/gears?
Old Feb 24, 2005 | 04:13 PM
acy76's Avatar
Default Re: ls tranny (civic2slo)
If you're referring to LS transmissions 92+, then:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2slo &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if my 99 si tranny diff. broke can I use a LS diff. ?</TD></TR></TABLE>
Yep, same part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2slo &raquo;</TD></TR><TR><TD CLASS="quote"> Just remove the broken one and replace it without changing the ring gear (is it the same?).</TD></TR></TABLE>
No, you will have to use the Si ring gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2slo &raquo;</TD></TR><TR><TD CLASS="quote">Are the LS syncros/gears? interchangable with the Si's? what would I have to do to switch the syncros/gears?</TD></TR></TABLE>
You would have to compare part numbers. You could start by checking ratios -- if they're the same for a given gear, chances are decent that they will be the same part. You might find that 1st gear is the same, but I would guess that none of the others are.
The synchros for all gears 1,3,4,5 and R will most likely be the same. 2nd gear synchro in the VTEC transmissions is dual-cone, and thus not the same as the LS.
You could also swap the internals over completely if you wanted to.
http://www.acuraparts247.com and http://www.slhonda.com are great sites for checking part numbers. Honda and Acura numbers will interchange -- check the Si diff against an LS diff.
Old Mar 5, 2005 | 06:06 PM
civic2slo's Avatar
Default Re: ls tranny (acy76)
thanks for all the info.
CaseBone
May 21, 2008 09:56 PM
TypeSLO
Sep 19, 2007 06:18 PM
blackb16209
10
Jan 9, 2007 05:45 PM
OOOOOOO
Jun 16, 2004 08:59 AM
nY's FiNeSt
Jul 8, 2003 03:05 PM
