ECU pins and wiring???
Old Feb 23, 2005 | 07:33 PM
ITR.#1446's Avatar
Default ECU pins and wiring???
I am doing a gsr swap on my brothers 91 DA and i got a pr3 instead of using the p72 that came with it. I am wondering how do i wire the vtec now and what pins is it. What else do need to wire if there is anything? I need some help this is my first swap. Thanks
Old Feb 23, 2005 | 07:52 PM
ITR.#1446's Avatar
Default Re: ECU pins and wiring??? (ITR.#1446)
any info
Old Feb 24, 2005 | 08:45 AM
JDMotive's Avatar
Vtec solenoid= A8
Vtec pressure switch = B5
2nd o2 = C8
Knock = B19
Old Feb 24, 2005 | 08:52 AM
ITR.#1446's Avatar
Default Re: ECU pins and wiring??? (JDMotive)
cool thanks now how do i read the pins across i read A is the biggest, then b is the middle and C is the last. How many O2 sensors do i have to run besides the one wire one it has already?
Old Feb 24, 2005 | 09:42 AM
JDMotive's Avatar
Pins on the top row are odd,pins on the bottom are even.
1 3 5 7 9 11
2 4 6 8 10 12 etc..
You need two o2 sensors..both are one wire.
Old Feb 24, 2005 | 04:04 PM
ITR.#1446's Avatar
thanks
Old Apr 28, 2005 | 05:56 PM
ITR.#1446's Avatar
ok went to put the ecu in and followed what you said and i ran all the pins ecept for the knock......i went to b19 and there was already a wire there? the car is a 91 ls and idk if it had a knock sensor...........i hate computers and wiring
Modified by ITR.#1446 at 4:30 AM 5/2/2005
Old May 1, 2005 | 07:30 PM
ITR.#1446's Avatar
anyone?
Old May 2, 2005 | 08:59 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">ok went to put the ecu in and followed what you said and i ran all the pins ecept for the knock......i went to b19 and there was already a wire there? the car is a 91 ls and idk if it had a knock sensor...........i hate computers and wiring
what year is the DA you're performing this GSR swap on?
also, check out these wiring diagrams:
OBD-0 (89-91 vehicles):
http://www.ff-squad.com/tech/w...1.jpg
OBD1:
http://www.ff-squad.com/tech/w...5.jpg
Modified by Katman at 1:41 PM 5/3/2005
Old May 2, 2005 | 11:26 PM
ITR.#1446's Avatar
Default Re: ECU pins and wiring??? (Katman)
its obd0 the link you posted was down.....idk what to do
Old May 3, 2005 | 12:39 PM
Katman's Avatar
ok the pinouts that were given to you were wrong, those are pinouts for an OBD1 ecu.
OBD-0 VTEC pinouts are shown here:
Old May 3, 2005 | 05:50 PM
ITR.#1446's Avatar
thanks bro i have no clue when it comes to ecu's and stuff.......the only prob i have know is i have an extra conector on the wiring harness in the back where oil temp sensor is......i have no clue as to what i did wrong there
Old May 3, 2005 | 06:01 PM
ITR.#1446's Avatar
one ?.........in the sec and third pic hte spots are filled and it has a wire, do splice the wire or what do i do???
Old May 3, 2005 | 07:28 PM
ITR.#1446's Avatar
also one more question............it say one wire for the oil pressure but 2 wires come out of the plug is one ground??
Old May 4, 2005 | 07:33 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">also one more question............it say one wire for the oil pressure but 2 wires come out of the plug is one ground??</TD></TR></TABLE>
yes, one is power one is ground, usually the black wire is ground. You can just ground the ground wire to the body of the VTEC solenoid.
Old May 4, 2005 | 11:27 AM
ITR.#1446's Avatar
cool now for the other question about the wires already there and then i think im good.....thanks
Old May 5, 2005 | 10:34 AM
ITR.#1446's Avatar
i just tried to do b19 and it already has a wire tho.......what is the iab solenoid also?
Old May 5, 2005 | 02:50 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">i just tried to do b19 and it already has a wire tho.......what is the iab solenoid also?</TD></TR></TABLE>
IAB is for the GSR engine, controls the secondary butterflies in the intake manifold. If you don't have a GSR intake manifold or ecu, no need to worry about it.
You sure B19 isn't empty? looking at the plug the right way (from behind as the my diagram shows?)
I'll have to check what B19 pin out is exactly....
Old May 5, 2005 | 04:49 PM
ITR.#1446's Avatar
yea im running a skunk2 mani.............yea idk there was a wire im sure
Old May 8, 2005 | 10:03 PM
ITR.#1446's Avatar
ok went g2ic and looked up ECU pin outs..........b19 on the pr3 is the knock sensor and i said there was a wire there..........i looked it up under the original pr4 and it said P/S Oil Pressure Switch.........what does that mean and on the pr3 its c9 pin out but on the pr4 the pin out is PA sensor............is that power steering i dont remember what wene to what exactly.....anyone helo me out please im so close to bein done but yet so far...
Old May 8, 2005 | 10:08 PM
ITR.#1446's Avatar
also just saw a10 pressure regulator cutoff solenoid valve..............i noticed before i removed the old motor the vacuum to the fuel pressure reg ran to the solenoid first but on a regular 94-01 teg it goes straight to the intake mani.........which way should i run the vaccum hose to it???
Old May 9, 2005 | 10:08 AM
ITR.#1446's Avatar
any info for me im really dumb
Old May 9, 2005 | 03:41 PM
ITR.#1446's Avatar
help me
Old May 9, 2005 | 07:46 PM
ITR.#1446's Avatar
integrawow
Nov 6, 2006 08:00 PM
DeezNutts
Mar 19, 2006 11:25 PM
Bseriesy0
Sep 21, 2004 09:43 AM
JMX
Nov 21, 2002 07:12 PM
TurboMiata
Dec 16, 2001 03:51 PM
