turbo d16 [z6 or y8]
Old Feb 23, 2005 | 06:54 PM
eK9aT10pSi's Avatar
Default turbo d16 [z6 or y8]
ive been hearing diff amts of oil to put in. stock i believe is 3.5qt. some ppl say put 4, i usually do ~3.75gt. what are ya'll puttin in ?
f.y.i. mobil 1 syn 10w30
Old Feb 23, 2005 | 07:13 PM
b1ackc1v1c's Avatar
Default Re: turbo d16 [z6 or y8] (eK9aT10pSi)
Royal Purple...4
Old Feb 23, 2005 | 08:45 PM
eK9aT10pSi's Avatar
Default Re: turbo d16 [z6 or y8] (b1ackc1v1c)
others ...
Old Feb 23, 2005 | 08:59 PM
lojackgsr's Avatar
dude i seriously believe is 3.5 I know 4 is to much for a facttt!
Old Feb 23, 2005 | 09:00 PM
eK9aT10pSi's Avatar
Default Re: turbo d16 [z6 or y8] (driftinitup)
stock is 3.5 i usually add 1/4 quart for the turbo.
Old Feb 23, 2005 | 09:10 PM
stealthmode62's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">stock is 3.5 i usually add 1/4 quart for the turbo.</TD></TR></TABLE>
Same.
Old Feb 24, 2005 | 07:10 PM
eK9aT10pSi's Avatar
Default Re: turbo d16 [z6 or y8] (stealthmode62)
bump
Old Feb 24, 2005 | 07:24 PM
thermal's Avatar
always made it 4 qts even
Old Feb 24, 2005 | 07:41 PM
jdm 94 eg freek's Avatar
Default Re: turbo mini me
Anyone help me i have a large problem i have project car i would like to finish by 2/27/05 and i need some help first i need a front mount reasonaly cheap and a info on shave a block down for turbo clearance
Old Feb 24, 2005 | 08:01 PM
eK9aT10pSi's Avatar
Default Re: turbo mini me (jdm 94 eg freek)
you mean notch the block? all you do is take a grinder and shave off part of the webbing on the motor. just enough so the turbo wont rub. get a johnny racecar fmic. like 180 shipped . i customized a starion fmic to get 2.25 endtanks
Old Feb 26, 2005 | 07:54 AM
eK9aT10pSi's Avatar
any other inputs ?
Old Feb 26, 2005 | 07:58 AM
oxSLEEPERxo's Avatar
i don't think oil lines and the turbo holds 1/2 quart, its probably around 1/4 of a quart, maybe a bit less, but i would just do 3 3/4 and not 4 quarts
Old Feb 26, 2005 | 03:16 PM
eK9aT10pSi's Avatar
Default Re: turbo d16 [z6 or y8] (oxSLEEPERxo)
alright then, i guess ill stick to 3.75 qt then
Old Feb 26, 2005 | 03:58 PM
W O T's Avatar
Ya I would think your oil feed/return/turbo itself and if you have a mechanical would be just about (little under) a quarter quart
Old Feb 26, 2005 | 07:10 PM
eK9aT10pSi's Avatar
Default Re: turbo d16 [z6 or y8] (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">Ya I would think your oil feed/return/turbo itself and if you have a mechanical would be just about (little under) a quarter quart</TD></TR></TABLE>
what mechanical thing are you talking about ?
Old Feb 26, 2005 | 07:20 PM
W O T's Avatar
mechanical oil pressure gauge, cant believe I forgot to put that lol
Old Feb 26, 2005 | 07:34 PM
miro_gt's Avatar
I put regular Mobil 1 - 10w40 for $1.18 /bottle .... car holds 3.5 Qt, dont put more than 3.75 ...as for how much the turbo holds - put 3.5 Qt and see where the mark on your dip stick is so add a little more ... on mine stock D16Z6 with 3.5 qt it goes up to the upper mark
if you put 4 qt then your oil will rise its temperature - not much, but you don't want it hotter but rather cooler
Old Feb 26, 2005 | 07:59 PM
W O T's Avatar
Default Re: turbo d16 [z6 or y8] (miro_gt)
Your oil temp will decrease with more oil obviously, more surface area, more mass for the molecules to lose speed hence cooling down
I put 4qt in mine because I aint boosted and she eat a quart every 550-600km/s
Old Feb 26, 2005 | 08:09 PM
miro_gt's Avatar
obviously it won't!
-&gt; more oil -&gt; need more time to cool off -&gt;keep higher temperature
Also, the speed of the molecules does not depend on mass, it depends on density, temperature, mixtures... Learn some physics
Old Feb 27, 2005 | 09:09 PM
eK9aT10pSi's Avatar
did an oil change today to see. i did 3.75 and it worked out fine. did 3.5 first, started car for 10-15sec. turned off, checked dip stick, added another 1/4. and it was all good.
allmotor b20 crx
Feb 7, 2008 05:40 PM
Historyg
Oct 24, 2007 05:13 AM
foowitdaredek
12
Apr 22, 2007 11:56 AM
walsh22
Mar 14, 2007 11:50 AM
Vtakkk
Jul 4, 2006 04:53 PM
