05 RSX-S gears grinding
Old Feb 23, 2005 | 06:21 PM
RSXisS's Avatar
Default 05 RSX-S gears grinding
I thought i read this topic a while ago but I can't find it. I'm having some grinding between shifting 2-3 and 3-4. I've got 600 miles. Any ideas?
Old Feb 23, 2005 | 07:30 PM
rough_draft's Avatar
Default Re: 05 RSX-S gears grinding (RSXisS)
take it back to the dealer?
Old Feb 23, 2005 | 07:34 PM
RC211V's Avatar
learn to shift.
Old Feb 23, 2005 | 08:23 PM
RSXisS's Avatar
Default Re: 05 RSX-S gears grinding (Civic CX Hatch)
**** you
Old Feb 24, 2005 | 12:52 AM
DC5ITR329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic CX Hatch &raquo;</TD></TR><TR><TD CLASS="quote">learn to shift. </TD></TR></TABLE>
lol drive it a little more and if the problems still there bring it back to the dealer.
Old Feb 24, 2005 | 11:53 AM
silver comet's Avatar
take it back to the dealer.
Old Feb 24, 2005 | 12:47 PM
JDM2ndGen's Avatar
Default Re: 05 RSX-S gears grinding (silver comet)
does it grind all the time or just in high rpm's and etc ...i would take it back to the dealer ...
Old Feb 24, 2005 | 02:15 PM
96integra20's Avatar
Is this the first manual shift acura/honda you have drove? Have you brought it back to the dealer yet?
Old Feb 24, 2005 | 03:09 PM
RSXisS's Avatar
Default Re: 05 RSX-S gears grinding (96integra20)
I took it to the dealer today. They said everything's fine. Supposedly there's 3 syncros involved in gears 1-2-3 and 2 syncros in gears 3-4 and 4-5 and 5-6. This is there to prevent downshifting from 6 to 5 and accidently downshifting to 3 and blowing out your engine. I know it's not my shifting technique and it's not my imagination, because there are multiple posts on this site and club rsx with the same problem on 05 Type-S. If i shift really slow and softly it's not too apparent, but if I shift normally, there's still a crunchy shift from 1-2 and 2-3. I guess I'll just drive it and if it gets worse I'll have to bring it to the dealership and hopefully they'll replace the syncros. But there are multiple posts of people who had their transmissions rebuilt and syncros replaced and the problem was worse than before they brought it in. Pretty shitty for a 24K car and for a Honda. Maybe they'll have a service bulletin as time goes on and the problem becomes more apparent, and they'll figure out what's wrong and fix it.
Old Feb 24, 2005 | 06:17 PM
NiPBoi's Avatar
ummm im pretty shure its not the 05 that had the prob wasnt it the 02-04 ep???...cuz i got an 05 and i never grind unless i try to downshift into the wrong gear...like say im goin 10mph and try to put it back into 1st..thats the only time i grind
Old Feb 25, 2005 | 08:11 AM
shyne's Avatar
i kinda had a problem with this to, especially when the car is cold.
Old Feb 25, 2005 | 01:40 PM
AcCO12D95's Avatar
I have the 1-2 crunch/grind when the car is cold. My method to avoid any crunching or grinding is to swing the shifter into neutral for a split second then into 2nd, instead of going straight down from 1 to 2nd. It does take more work, but I just do it till the car is a little warmed out and then proceed with just normal shifting.
Old Feb 25, 2005 | 04:26 PM
johnkimble's Avatar
Default Re: (AcCO12D95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcCO12D95 &raquo;</TD></TR><TR><TD CLASS="quote">I have the 1-2 crunch/grind when the car is cold. My method to avoid any crunching or grinding is to swing the shifter into neutral for a split second then into 2nd, instead of going straight down from 1 to 2nd. It does take more work, but I just do it till the car is a little warmed out and then proceed with just normal shifting.</TD></TR></TABLE>
i do the same
Old Feb 26, 2005 | 12:47 AM
RSX-typeS's Avatar
I find I have the same problem on my RSX as well. When the engine is cold between 1-2 there is a crunching. I haven't experieced any grinding between 2-3 as the original poster said he had. If you just try to shift slow and smooth while the car is cold (you shouldn't have your foot in it when it's cold anyway) it minimizes the problem.
Old Feb 26, 2005 | 06:28 AM
Fac3Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSXisS &raquo;</TD></TR><TR><TD CLASS="quote">I took it to the dealer today. They said everything's fine. Supposedly there's 3 syncros involved in gears 1-2-3 and 2 syncros in gears 3-4 and 4-5 and 5-6. This is there to prevent downshifting from 6 to 5 and accidently downshifting to 3 and blowing out your engine. I know it's not my shifting technique and it's not my imagination, because there are multiple posts on this site and club rsx with the same problem on 05 Type-S. If i shift really slow and softly it's not too apparent, but if I shift normally, there's still a crunchy shift from 1-2 and 2-3. I guess I'll just drive it and if it gets worse I'll have to bring it to the dealership and hopefully they'll replace the syncros. But there are multiple posts of people who had their transmissions rebuilt and syncros replaced and the problem was worse than before they brought it in. Pretty shitty for a 24K car and for a Honda. Maybe they'll have a service bulletin as time goes on and the problem becomes more apparent, and they'll figure out what's wrong and fix it.</TD></TR></TABLE>
My 05 transaxle never grinds on the 1-2, my shifter doesnt pop out of third gear, my shifter never has excessive vibration, if there is a problem its most likely the dirver. I've spent some time reading clubrsx forums and its pretty funny what I see on there.
Blackline47
Honda Civic (2006 - 2015)
16
May 27, 2007 10:48 PM
greddy13
Apr 24, 2006 06:13 PM
LvN
Apr 20, 2006 08:57 AM
vernfin
Honda S2000
35
Dec 6, 2005 09:10 AM
arren123
Jul 3, 2002 01:33 PM
