HEY MISA, or anyone with portmatching exp.
where can i get some info on port matching? i plan on doing some research on tuesday but didnt know if maybe there was some place online that had some info?
what kind of info are you looking for? its relatively easy man, trace what the intended size is to be, color and take your grinding bit and grind away until you have the needed size, make sure to take the plenum OFF to do this, also you will need to cut a new tb gasket
