Honda S2000 Honda S2000
18" Professor...Will I rub?
Old Feb 23, 2005 | 03:30 PM
04RioS2k's Avatar
Default 18" Professor...Will I rub?
Hey all I'm planning on picking up a set of 18" SSR Professor and was wondering with size of 18x8 front with +55 and 18x9.5 rear with +59 offset. I'm also planning on dropping the car with eibach/koni which would be a a 1.25-1.5 inch drop. I also heard that I might have to run a little negative camber which is no problem but possibly having to roll my fenders is something I don't want to do. So would anyone here think I'll be okay and if so what size and type of tire should I run with this set up, thanks for any feedbacks.
John
Old Feb 23, 2005 | 04:16 PM
papa5murf's Avatar
Default Re: 18" Professor...Will I rub? (04RioS2k)
you should be ok.. but you might rub a little.... make sure you pick up the right tires with the sidewall that goes inwards a little to avoid rubbing...... rolling your fenders would be highly recomended, and will give you a lot more clearance..
Old Feb 23, 2005 | 05:44 PM
RiceMasterChang's Avatar
ya u should be fine
Old Feb 23, 2005 | 06:06 PM
boostdd's Avatar
post pics when you do
Old Feb 23, 2005 | 08:21 PM
04RioS2k's Avatar
Default Re: 18" Professor...Will I rub? (03s2kblue)
thanks for all the reply so far.....also about rolling the fender I just don't like the idea of doing something major like that to my fender what if I messed it up or something....also could you name me some tires that goes inward? Thanks
John
P.S. Pics will definitely be up if I get the wheels
Old Feb 23, 2005 | 10:42 PM
papa5murf's Avatar
contact jim at tire rack... he'll give you all the tire options for the setup you're going with....
as for the fender rolling i'm sure you could probably find a place that can do it for you.. if you mess up on it you'll get a couple of little tiny dings here and there... and i've heard you can actually rent/borrow the fender rolling unit from pepboys and you'll also need a heat gun to do it.... if you end up doing it make sure you keep constant heat on the fender... but do not make it to hot cause if you get it to hot you will melt the paint... but you need constant heat so it will have a smoother finished product in the rolling....
Old Feb 25, 2005 | 07:18 AM
importluvvv's Avatar
Is rolling the fender the same as pulling the fender? I've heard of people pulling the fender to for low offset wheels, that stick out the fender.
Old Feb 25, 2005 | 08:08 AM
papa5murf's Avatar
Default Re: 18" Professor...Will I rub? (importluvvv)
rolling the fender is when you roll the inside piece and make it flat with the fender..
silver05civicLXse
Sep 11, 2011 01:23 PM
millllenium
Apr 3, 2009 12:45 PM
Godspeed07
Feb 25, 2009 06:09 PM
EgSalad
Oct 19, 2005 10:05 AM
ITRiWISH
Aug 29, 2004 09:53 AM
