tranny questions!!!
Old Feb 23, 2005 | 03:16 PM
turbohybridhatch's Avatar
Default tranny questions!!!
i have a 98 gsr tranny with itr lsd will it hold up to 400-500 hp with no mods? running act xtreme street clutch and launching on 24" slicks on race day.. also who does tranny rebilds reliably and reasonably priced in arklatex area?? syncs are going out...
Old Feb 23, 2005 | 03:31 PM
86si's Avatar
Default Re: tranny questions!!! (turbohybridhatch)
the diff will hold for a while, get a quaife if you want it to last. Trans should be OK. a Phantom grip cradle would be a good investment if your going to have the trans apart for syncros.
Old Feb 23, 2005 | 03:51 PM
Group Tenacity's Avatar
You might also look into getting a difforant clutch...
Here is s pic of what happened to my ACT clutch on its first attempt down the track with just over 530whp... Dont get me wrong, ACT clutches are good products, but as you can see, i dont think they do good with high hp...
As 86si said, you will want to look into another diff. later and the tranny cradle is a good investment, but you loose 5th gear, so if its a street car, you might not want to go that route...
Mike...
Old Feb 23, 2005 | 04:13 PM
toyotaturbo's Avatar
Default Re: tranny questions!!! (Group Tenacity)
Your pics are interesting. We use an ACT clutch, and we went the entire season without replacing anything at all. The final pass of the season on the very clutch we're starting this season with went 8.43@155mph. Our car weighs 2440 lbs, also.
http://www.paradiseracing.com
Old Feb 23, 2005 | 08:14 PM
Default Re: tranny questions!!! (boost_dependent)
Im glad you had success with the ACT clutch... Dont get me wrong, as i said before, they make great products... I still use ACT clutches in my other cars... I personly dont trust them over 500whp, but thats just me and because of my previous experience...
I cant tell you why my clutch did what it did, but the only use on the clutch was 8 dyno pulls, then a burn out and launch and when i started engauging the clutch to go to 2nd gear, BANG!... (shrugs) maybe i had a defective clutch, i dont noe... I hope your luck continues with the ACT clutch...
Mike...
Old Feb 24, 2005 | 05:37 AM
g2turbo's Avatar
Mike what model ACT clutch were you using?
Old Feb 24, 2005 | 06:17 AM
Aggressive Racing's Avatar
Like (Group Tenacity) said a different clutch would help,preferably a twin disc.
Old Feb 24, 2005 | 09:48 AM
Default Re: tranny questions!!! (g2turbo)
It was the ACT 6 puck clutch with Extreme pressure plate...
Mike...
Old Feb 24, 2005 | 01:32 PM
yea i need fifth gear no trailer queen here... id love to step up to a better clutch and diff but moneys tight.. if this set up will hold for long enough to save up for new parts id be estatic
Old Feb 24, 2005 | 02:37 PM
S13Sean's Avatar
What's everyone's opinion on cable vs hydraulic B-series transaxles? What is the difference other than the method of actuation of the clutch?
Old Feb 24, 2005 | 04:51 PM
86si's Avatar
Default Re: (S13Sean)
early cable trannies had a smaller main shaft which makes them weaker. other than that they are basically the same.
Old Feb 24, 2005 | 06:00 PM
N2O's Avatar
N2O
Default Re: (86si)
Smaller main had nothing to do with it. The cable trans has a 25.4 mm input and the hydro has a 26mm. Cables are said to engage faster but the cases are becoming hard to find. You can put hydro gears in a YS1 case but good finding one.
Old Feb 24, 2005 | 06:47 PM
Suprdave's Avatar
Default Re: (N2O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote">You can put hydro gears in a YS1 case but good finding one.</TD></TR></TABLE>
I've got a couple...
Old Feb 24, 2005 | 06:48 PM
Suprdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohybridhatch &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 gsr tranny with itr lsd will it hold up to 400-500 hp with no mods? running act xtreme street clutch and launching on 24" slicks on race day.. also who does tranny rebilds reliably and reasonably priced in arklatex area?? syncs are going out...</TD></TR></TABLE>
Clutch = Weak Link.
You shouldnt break much on 24s tho...go for it.
Old Feb 24, 2005 | 06:56 PM
N2O's Avatar
N2O
Default Re: tranny questions!!! (Suprdave)
Sure now you do have them. Now that I do not need them anymore.
Old Feb 24, 2005 | 09:16 PM
Ls1 FD3s's Avatar
Default Re: tranny questions!!! (N2O)
honestly 150whp, 500whp, its how you drive moreso. My freind with his b16 CRX and ys1 LSD trans/ACT streeet strip clutch learned the hard way. Heated up nitto 555rs, revved her to 7200, straight dumped it, and pop goes the weasle. he snapped axle housing part of the LSD (where the axle's splines insert into the LSD, dont know the real name/wording) Car was a turd, 15.6 or some ****, prolly 145whp.
Im currently installing an ITR LSD into my gezzer trans (patting myself on the back ) and have questioned as well, how much HP is this sucker good to. A quiafe and or CoughcoughOBXcoughcough could be in the near future. I have a Kaaz for the Rx7. If your going to make serious power and want strength, you have to pay to play.
When i launch, i dont straight dump tho, i let it out ever soo lightly that i can feel everything in the driveline tighten up without the car actually moving (hard to master) Then let it out kinda quickly. This way everything does'nt get a sudden jolt like you would straight dumping it. Thats my technique, not sure if it holds any truth/practice to it, but ya.
Old Feb 26, 2005 | 04:39 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">Im glad you had success with the ACT clutch... Dont get me wrong, as i said before, they make great products... I still use ACT clutches in my other cars... I personly dont trust them over 500whp, but thats just me and because of my previous experience...
what about a 4 puck instead, would that be better since your putting out that much?
Old Feb 27, 2005 | 11:30 AM
Default Re: tranny questions!!! (93blkej1)
I dont noe if the 4 puck will hold more power or not... Maybe someone else will noe this answer... Im using an Exedy twin disk clutch now and have no problems...
Mike...
Old Feb 27, 2005 | 12:33 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">I dont noe if the 4 puck will hold more power or not... Maybe someone else will noe this answer... Im using an Exedy twin disk clutch now and have no problems...
Mike...
I don't think the 4 puck will hold more power. I started off with an ACT xxtreme kit and the 4puck in my crx. After 20 dyno pulls and 5 full passes at the track it started slipping at only 509whp and 351tq on 25" slicks. I switched to a twin disc and never looked back.
Lolstophatin
Feb 7, 2009 03:58 PM
kaimo
Feb 3, 2004 02:03 AM
Bspec18
Jul 11, 2003 09:25 PM
