d15b
Old Feb 23, 2005 | 03:13 PM
wfo's Avatar
wfo
Default d15b vtec ?
We swapped the d15b into my friends 95 civic hatch, were not sure if vtec is kicking in or not but if it was wired wrong into the ecu wouldnt it throw a code? and were using the p08 ecu
Old Feb 23, 2005 | 03:47 PM
Ignitecivic's Avatar
Default Re: d15b vtec ? (wfo)
yeah it should at least throw a code. try to run some code.
Old Feb 23, 2005 | 06:11 PM
wfo's Avatar
wfo
we've checked for codes but nothing...some ppl have said that the p08 ecu isn't as good to use as the p28
Old Feb 23, 2005 | 07:40 PM
sockvtec's Avatar
is it the vtec d15? there is a non vtec d15 right?
Old Feb 23, 2005 | 07:45 PM
straggs42d15's Avatar
my buddy and i swapped a d15b into one of my buddies civic and the vtec solenoid wasn't hooked up all the way so vtec didn't hit and it <U>did</U> throw a code. um vtec in a d15 is kinda weak sauce tho you can barely tell its there so maybe you guys are hitting vtec and just not hearing it? i dunno hope i helped good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burns &raquo;</TD></TR><TR><TD CLASS="quote">is it the vtec d15? there is a non vtec d15 right?</TD></TR></TABLE>
i think the d15b (jdm) is vtec and the d15b7 (usdm) is not vtec i dont know alot tho someone correct me
Old Feb 25, 2005 | 12:04 PM
wfo's Avatar
wfo
i think its kicking in its just weak.lol but were gonna check over the wiring today or tomrow
Old Feb 25, 2005 | 12:16 PM
POE's Avatar
POE
you can hear vtec open up at 4800 if its working.
Old Feb 25, 2005 | 12:17 PM
POE's Avatar
POE
start in 2nd gear going 20mph and WOT all the way tell 7000 and you should tell if its working or not. also try another ecu, like a p28 if u have access to one
Old Feb 25, 2005 | 02:21 PM
Default Re: (POE)
let us drive the car, we tell u if its working.
nkcalvert09
Jun 11, 2011 10:43 PM
slowr6
Mar 27, 2007 04:51 PM
MugeNinja
Dec 29, 2005 09:50 AM
JunY
Honda S2000
18
May 17, 2005 09:37 AM
