Anybody got pics of a 3" downpipe on their lude?
Old Feb 23, 2005 | 01:21 PM
ChrisRicketts's Avatar
Default Anybody got pics of a 3" downpipe on their lude?
i've got a 2.5" dp on mine, but i've seen somewhere that a guy was able to fit a 3" dp while keeping a/c.......not even using some fancy sidewinder mani or anything like that. i think it was something like a rev-hard, drag, or turbonetics mani. i had a hell of a time fitting my 2.5" in there, and that's shaving and cutting a few things too.
so like i said, if you've got a 3" dp.......let's see it.
Old Feb 23, 2005 | 01:48 PM
Sam1am26's Avatar
Default Re: Anybody got pics of a 3" downpipe on their lude? (ChrisRicketts)
I've seen it somewhere on here... I'm using a 2.5" and you could definitely make a 3" clear the AC if you have a nice tight bend but I'm not sure if you can clear the crossmember...
Old Feb 23, 2005 | 02:02 PM
Default Re: Anybody got pics of a 3" downpipe on their lude? (Sam1am26)
right.......a very tight bend. and i've already cut the lip off of my crossmember to fit the 2.5"........i guess i'd be willing to cut more to fit a 3". but i'd like to see pics.
Old Feb 23, 2005 | 02:28 PM
boosted lude's Avatar
3in will fit fine on the prelude... i ran one on my 01 lude and it cleared a/c and the crossmember fine... unfortunatly i have no pics b/c 2 days after i had the dp custom made my motor blew ... but to answer your ? yes a 3in definatly fits...
Old Feb 23, 2005 | 02:48 PM
fastludeh22's Avatar
Default Re: Anybody got pics of a 3" downpipe on their lude? (boosted lude)
i had a drag gen 4 w/ac and ps at the time and 3" dp...well the first 3" or sowas 2.5 cause it was hard to clear everything i had at the time...dont quote me but i think the prob was the bend that was needed w/the ps made it impossible to put a bolt in the bottom of the 4 bolt housing w/a 3" pipe...was hard w/the 2.5, so i used a stud kit...
hold on a min for pics
Old Feb 23, 2005 | 04:42 PM
Default Re: Anybody got pics of a 3" downpipe on their lude? (fastludeh22)
i think that's one of the main problems with a 3" dp......is that the bend has to be so close to the flange that it's hard to get the bolts in it. if there was a v-band t3 sc-61 that would be awesome, but unfortunately there's not. i know it can be done because i've seen pictures before, but i'd like to look at them again to see how things were done in that tight space.
Old Feb 23, 2005 | 07:04 PM
93H22Turbo's Avatar
I used to have 3" downpipe, but it used scrape because it was too low. Now I got 2.5" downpipe and no scrape. I got South Florida Performance manifold and it is hard to clear everything, so I took the AC compressor and some of the AC lines out. I have to cut a piece off engine mount to fit the turbo and even shave the block.
This is my 2.5" downpipe my brother made for me.
This is how it looks after the engine is finish.
Old Feb 23, 2005 | 07:17 PM
Default Re: Anybody got pics of a 3" downpipe on their lude? (93H22Turbo)
looks good man. i like the way you routed your ic piping.....must be a lot easier without those M@TH#A$F#@CK$^NG a/c lines in the way. I can't tell you how bad i wanted to rip those bitches off and burn them when i was routing mine. I shaved my motor mount down a lot too.......it looks just like yours. i've also got the sfp mani, so i'm glad to see that you got the 3" dp in there. thanks for the pics.
Old Feb 23, 2005 | 07:21 PM
Pullig's Avatar
you still got that H23 turbo manifold for sell
Old Feb 23, 2005 | 07:22 PM
93h22turbo----i'm curious.....is your dumptube really curvy? mine had to go down under the radiator hose, then back up over the clutch master cylinder lines then back down straight to the ground. i know that's what is causing me to creep so bad, but i couldn't find a better route.......is that how you did yours?
Old Feb 27, 2005 | 04:55 PM
93H22Turbo's Avatar
Default Re: Anybody got pics of a 3" downpipe on their lude? (Pullig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">you still got that H23 turbo manifold for sell
Yes I still have the H23 Drag turbo manifold for sell.
Old Feb 27, 2005 | 05:01 PM
93H22Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts &raquo;</TD></TR><TR><TD CLASS="quote">93h22turbo----i'm curious.....is your dumptube really curvy? mine had to go down under the radiator hose, then back up over the clutch master cylinder lines then back down straight to the ground. i know that's what is causing me to creep so bad, but i couldn't find a better route.......is that how you did yours?</TD></TR></TABLE>
yes mine is too curvy, but mine goes to the close to the block and motor mount than to the ground.
Old Feb 27, 2005 | 06:19 PM
Pullig's Avatar
sent an email to you
Old Feb 27, 2005 | 06:23 PM
Beau Gotti's Avatar
i got the same problem you are having, i gotta shave some of my block, how much of a risk is there cutting the front engine mount bracket i need to shave a good bit of it off, little more than you i believe, when you swap the h22 in a hatch, you dont even use that mount, do ya? so is it there just for added benefit?
Old Feb 27, 2005 | 08:20 PM
stinger's Avatar
Default Re: (beaussol)
I could never get a 3" in mine either i got 2.5 and it sucks blah
Old Feb 27, 2005 | 08:39 PM
Default Re: (stinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaussol &raquo;</TD></TR><TR><TD CLASS="quote">i got the same problem you are having, i gotta shave some of my block, how much of a risk is there cutting the front engine mount bracket i need to shave a good bit of it off, little more than you i believe, when you swap the h22 in a hatch, you dont even use that mount, do ya? so is it there just for added benefit?</TD></TR></TABLE>
there's not really any risk in shaving the front motor mount. but i wouldn't remove it completely. i don't think it would end the world or anything if you did......but i wouldn't advise it. as far as the consequences.....i'm not really sure? maybe more vibration and it may let the engine rock back and forth more than usual, causing strain on the manifold and exhaust. that's just a guess......i guess.
Old Feb 28, 2005 | 07:04 AM
93H22Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">sent an email to you </TD></TR></TABLE>
Reply the email to you.
Old Feb 28, 2005 | 07:14 AM
93H22Turbo's Avatar
There is no risk on cutting the front motor mount bracket. If you want buy the red motor mount insert like me for front and back it makes your engine stiff. Since I put that in my engine never rocks. See picture....
Old Feb 28, 2005 | 08:12 AM
Pullig's Avatar
are you sure cuz i havent recieved one from you talk to me on AIm Cpullig1585 thanks
Old Feb 28, 2005 | 10:35 AM
prelittlelude's Avatar
ehhh i have a 3 inch dp without a/c does that count??
Old Feb 28, 2005 | 11:47 AM
Default Re: Anybody got pics of a 3" downpipe on their lude? (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">ehhh i have a 3 inch dp without a/c does that count??</TD></TR></TABLE>
no that doesn't count. but it counts if you have a 4" dp with no a/c.
Old Feb 28, 2005 | 03:22 PM
93H22Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote">are you sure cuz i havent recieved one from you talk to me on AIm Cpullig1585 thanks</TD></TR></TABLE>
I sent you IM to this screen name.
gogunkergorilla
Mar 29, 2007 03:28 PM
divingcorners
Aug 28, 2006 03:13 PM
egzboy
Honda Fit
Jul 16, 2006 07:47 AM
project dc2
Mar 9, 2003 01:06 PM
asianspeed
Jan 26, 2003 07:34 PM
