Help: Need OBDIIA codes...
Old Feb 23, 2005 | 01:12 PM
5po0n_Dc2's Avatar
Default Help: Need OBDIIA codes...
My check engine light is throwing me code 21 (4 long pauses and 1 short, right?). I was wondering if anybody has the book or can tell me what the code is reffering to. Thanks.
Old Feb 23, 2005 | 02:04 PM
JimBlake's Avatar
Default Re: Help: Need OBDIIA codes... (5po0n_Dc2)
21 would be the VTEC solenoid valve (or it's circuit). There's a sticky-post at the top of the Integra forum...
Old Feb 23, 2005 | 05:53 PM
5po0n_Dc2's Avatar
Default Re: Help: Need OBDIIA codes... (JimBlake)
Thanks, but I think it's code 41 (not 21). I don't have a OBDII reader, but I used CEL to read it, so if anybody can tell me what that code is it will be helpful.
Old Feb 23, 2005 | 08:08 PM
ekb16's Avatar
https://honda-tech.com/zerothread?id=682412
21 VTEC spool solenoid valve
41 Primary oxygen sensor heater
Old Feb 23, 2005 | 09:51 PM
5po0n_Dc2's Avatar
Default Re: (ekb16)
Where is the primary oxygen sensor heater located? And what usually causes it to go bad?
Old Feb 23, 2005 | 09:58 PM
deSigi's Avatar
Default Re: (5po0n_Dc2)
Your primary O2 sensor is located before your cat. on your exhaust system. With a malfunction with the O2 sensor heater there are no specific causes for it to malfunction... at least I don't know any. It may just be that your sensor was due to be changed, because the heater element wasn't heating the sensor.
Old Feb 24, 2005 | 04:13 AM
JimBlake's Avatar
The heater is built into the O2 sensor. Measure resistance between the 2 same-color wires (black?) it should be 10 to 40 ohms. If not, buy a new sensor. If it's OK, then look for problems in the circuit that powers the heater.
ps: I should've said 10-40 ohms between the heater wires, with neither one having any continuity to ground.
Modified by JimBlake at 11:00 AM 2/24/2005
dbailey
21
Nov 9, 2007 07:08 AM
Speed94
Nov 10, 2006 04:51 PM
YaMaJeSty
Jul 26, 2002 04:01 AM
6SPD_EK
Feb 20, 2002 02:52 PM
