Missing link with uberdata?
Do i need to use the map sensor bypass valve missing link if i run uberdata? Seems as though i see people running it both ways. This is for a 7 psi drag setup running uberdata...also any advantage if i disable closed loop in uberdata?
no missing link for ueberdata. Ueberdata needs the MAP signal to be able to see what your turbo is doing. the missing link would keep UD from seeing boost and you'd lean out like a **** REALLY quick.
Turbohatch
Jul 2, 2001 10:35 PM
