96 Civic headlight connector/plug question please help!!
My headlight connector/plug on my 96 civic melted, I bought a new plug from honda, but the old one was so bad I can't even tell where the wires go. Could someone help me out and either take a picture of their plug (driver's side btw) or draw me a diagram of some sort? Thank you!!!
I'll take a picture for you after work. I know for sure high beam is on top. Low beam and Ground is what I forgot. Can you tell by the wire colors? White is high, ground is black and low i believe is brown.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saxqtzk »</TD></TR><TR><TD CLASS="quote">I'll take a picture for you after work. I know for sure high beam is on top. Low beam and Ground is what I forgot. Can you tell by the wire colors? White is high, ground is black and low i believe is brown.</TD></TR></TABLE>
The wires are red/yellow, red/green, and black. The new plug I bought just has two yellow wires and a red, thats why i need a picture or something so I can see where the wires go on the plug itself. Thanks for your help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch »</TD></TR><TR><TD CLASS="quote">
The wires are red/yellow, red/green, and black. The new plug I bought just has two yellow wires and a red, thats why i need a picture or something so I can see where the wires go on the plug itself. Thanks for your help!</TD></TR></TABLE>
Alright.
Wires on your car:
Black - Ground
Red/Green - Low Beam ?
Red/Yellow - High Beam ?
New Plug
Red - Ground ?
The 2 yellows should be high and low.
I'll take detailed pics for you when I get home. Don't worry about the 2 yellows and red... Just match them up to what the stock connectors are located.
Alright.
Wires on your car:
Black - Ground
New Plug
Red - Ground ?
alright, my battery is dead so i'll try to get you a picture later tonight.
Here is my diagram:
*Paint at it's best!
Driver Side Bulb Harness
I would highly suggest you pick up a multimeter this way you can avoid things like this. They're like $10-$20.
Here is my diagram:
Marvin1985
Nov 22, 2012 11:02 AM
PearlWhiteAccord
Feb 11, 2004 02:19 PM
