Technical Questions
Old Feb 23, 2005 | 06:50 AM
baggelis's Avatar
Default Technical Questions
Can someone please explain to me the difference in performance between a 4-1 header and 4-2-1 header? I would like to know the reason behind the difference (get technical). Also I have no clue on how the traction bar works, does it only help on a straight line or it is good for track use also?. Please explain
Old Feb 23, 2005 | 07:11 AM
tgreaves's Avatar
Default Re: Technical Questions (baggelis)
You need to understand how a header works.. As exhaust waves come out of the cylinder and passes by where another cylinders runner is they create a low pressure area which when the other cylinder's exhaust valve opens it sucks the exhaust out..
As the engines rpms increase the wave moves faster so its further down in the runners when the next cylinders valve opens, so a 4-2-1 header will give you more low-mid power and a 4-1 header will give you more mid-topend power..
Old Feb 24, 2005 | 06:49 PM
baggelis's Avatar
Default Re: Technical Questions (tgreaves)
What about the traction bar?
Old Feb 24, 2005 | 07:29 PM
sabotage7's Avatar
here is some good reading on Header-Exhaust Design Effects on Engine Power for you!
Old Feb 25, 2005 | 10:34 AM
baggelis's Avatar
Default Re: Technical Questions (sabotage7)
Thank you
That is exactly what I was looking for.
baggelis's Avatar
Anybody else with a similar article about traction bars?
Rinsta
Jun 24, 2009 01:48 PM
91preyludesi
Oct 29, 2005 12:20 PM
ITRacer121
70
Mar 29, 2005 02:34 PM
shinji666
Oct 10, 2004 07:03 AM
T3
Feb 26, 2003 05:34 PM
