pcb ecu pinouts
Old Feb 23, 2005 | 05:32 AM
Prelude SIR-T's Avatar
Default pcb ecu pinouts
i was wondering if anyone had the pinouts for the pcb ecu on the accord sir-t f20b any help would be great.
Old Feb 23, 2005 | 06:14 AM
blackdelslo's Avatar
Default Re: pcb ecu pinouts (jdmhore)
Thats only like in the top 10 rarest ecu's
Old Feb 23, 2005 | 06:37 AM
Default Re: pcb ecu pinouts (delLudeVTEC)
i know i need a pinout/wire scheme for the wires going into the pcb ecu to wire it up
Old Feb 23, 2005 | 06:54 AM
kulrevon's Avatar
That ecu is OBD2 right?
Old Feb 23, 2005 | 07:04 AM
Default Re: pcb ecu pinouts (kulrevon)
ya it is but i am not sure if it follows the regular obd2 scheme since it has that electric power steering, thats why i need the wires that are going into the pcb ecu so i can wire it to the obd1 p72
Old Feb 23, 2005 | 07:05 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhore &raquo;</TD></TR><TR><TD CLASS="quote">ya it is but i am not sure if it follows the regular obd2 scheme since it has that electric power steering</TD></TR></TABLE>
i bet it follows the normal obd2 scheme and then they just used odd pins that wern't used before.
are you trying to wires the elctric power steering?
Old Feb 23, 2005 | 07:15 AM
Default Re: pcb ecu pinouts (prelittlelude)
no i am not trying to do the electric power steering i am going to use my power steering pump off of my engine right now. so you think if i just get the jumper that will be all i need to do because i have the whole engine harness all the way to the ecu plugs and i am going to use the p72 obd1 so if i got the obd2a-obd1 jumper harness you think it would work perfectly?
Old Feb 23, 2005 | 07:19 AM
yeah i think it should work no problem
Old Feb 23, 2005 | 07:22 AM
you know if it is going to be the obd2b or the obd2a? i am not sure i think its obd2a so i can pull the wire scheme pinouts off line somewhere. o ya is this an accurate pinout chart?????? cuz it is the one i was going to use and i dont want anything frying http://www.hondaswap.com/forum...29360 , let me know thanks!
Old Mar 20, 2005 | 05:19 PM
ek9h22's Avatar
can you used the pcb ecu for a h22 engine?
Old Apr 19, 2006 | 03:18 PM
tommy.'s Avatar
Default Re: pcb ecu pinouts (ek9h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9h22 &raquo;</TD></TR><TR><TD CLASS="quote">can you used the pcb ecu for a h22 engine?</TD></TR></TABLE>
me wondering the same thing.....and isnt it obd2b?
Old Apr 19, 2006 | 06:40 PM
Default Re: pcb ecu pinouts (eg6b0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6b0i &raquo;</TD></TR><TR><TD CLASS="quote">
me wondering the same thing.....and isnt it obd2b?</TD></TR></TABLE>
save yourself the hassle and just get a p72 with hondata setup
crx_253
Northwest (Sales)
May 4, 2014 03:05 PM
vtecn8ive
Jul 18, 2009 02:19 PM
raidacaipo
16
Nov 14, 2008 11:23 PM
