dyno on b16 with buddyclub spec 3 cams and vafc
Old Feb 23, 2005 | 04:21 AM
toda_eg6's Avatar
Default dyno on b16 with buddyclub spec 3 cams and vafc
with my cams and vafc tuned this is what they got http://www.we-todd-did-racing....D.jpg
the green is the first run untuned, second is red and that is my vafc tuned, and the blue is the vafc and cams tuned i also have a j's racing intake, skunk2 intake manifold, dc 4-1 headder, test pipe and buddyclub racing spec III cat-back
Old Feb 23, 2005 | 05:39 AM
SkRiBLaH's Avatar
Default Re: dyno on b16 with buddyclub spec 3 cams and vafc (toda_eg6)
not bad i guess for a mild 1.6
Old Feb 23, 2005 | 06:54 AM
athoughts's Avatar
seems decent i suppose
i only made 164.4whp
with b16a2
p&p head
3 angle valve job
Stage 2 Gude cams
AEM cam gears/pullys
AEM fuel rail
B&M fpr
Bullfrog TB 62mm
aebs intake manifold
AEM cia
HKS cat back
4-1 header
I still feel mine is low tho
Old Feb 23, 2005 | 07:54 AM
CHEETAH's Avatar
how come you cut off so early and power still going up ?
good numbers for a b16a setup
greg
Old Feb 23, 2005 | 08:54 AM
ELABR8's Avatar
did u upgrade valvetrain? even tho i know u dont need it but its better to have it n would b able to squeeze couple more #s out of it
Old Feb 23, 2005 | 09:03 AM
flesh199's Avatar
Default Re: (egs4life)
athoughts
i have the same setup as you but i run itr 99 cam and put down 170whp/114lbs....
Old Feb 23, 2005 | 03:02 PM
athoughts's Avatar
Default Re: (flesh199)
mine put out 169whp once apon a time
what did you tune with
mine was tune with a stock ecu and vafc - hondata coming soon tho :D
Old Feb 23, 2005 | 03:42 PM
flesh199's Avatar
Default Re: (athoughts)
my car is converted obd1 with a p28 ecu
i have a p30 map and i played with my vafc ont the dyno...
mine put out 173 whp at the 14pull but we stay at 170 for now...
Old Feb 23, 2005 | 10:01 PM
toda_eg6's Avatar
Default Re: dyno on b16 with buddyclub spec 3 cams and vafc (CHEETAH)
my power kept going but my stock p30 wont go past 8200
Old Feb 23, 2005 | 10:03 PM
toda_eg6's Avatar
just the vafc and cams tuned no ignition no fuel mods every thing is stock except valve traine
Spoon ITR
Oct 12, 2005 05:20 AM
athoughts
34
May 25, 2005 08:57 AM
hb4u2nv
Jun 21, 2004 10:42 AM
EG_93Civic
11
Aug 7, 2003 07:39 PM
ActiveAero
Dec 27, 2002 10:53 AM
