OBD2b to OBD1 - what needed?
Hallo,
i have a OBD2b P73 ECU. what do i need to run a obd1 p30 ecu i.e. on a obd2b integra type r b18 engine.
i know i need the adapter harness and the obd1 ecu... and if i swap from obd0 to obd1 i need the o2 sensor and the distributor... but i'am not sure how it is with obd2 and obd1... maybe someone can help.
Thanks
Malte.
Thanks
Malte.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">all you need is the adapter harness and ecu. </TD></TR></TABLE>
that's correct.
platinum
that's correct.
platinum
As others have said, you need the OBD1 ecu and the conversion harness. Check here for the cheapest prices anywhere on the OBD conversion harnesses. No middle man. No internet pinout copiers.
https://honda-tech.com/zerothread?id=997093
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource »</TD></TR><TR><TD CLASS="quote">You will also need OBD1 Injector Clips - You will be running Peak and Hold injectors now instead of saturated.</TD></TR></TABLE>
i run saturated with my ODBI p28
platinum
platinum
What? I'm running P&H on my stock clips...no sweat.
OBD1 injectors are still Saturated. And he can keep the OBD2 injectors as well. If he wanted to go to Peak and Hold..OBD0 injectors, then he would need to install the resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">
OBD1 injectors are still Saturated. And he can keep the OBD2 injectors as well. If he wanted to go to Peak and Hold..OBD0 injectors, then he would need to install the resistor box.</TD></TR></TABLE>
You are correct - sorry for the mis info. . . I was thinking he was going to be running DSM injectors for some reason. . .I'm retarded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">As others have said, you need the OBD1 ecu and the conversion harness. Check here for the cheapest prices anywhere on the OBD conversion harnesses. No middle man. No internet pinout copiers.
Jason</TD></TR></TABLE>
damn you seem to have a good selection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">
I have the biggest selection PERIOD! I have been doing this for a while man. If someone is doing something custom and needs it, I will make it no problems.
</TD></TR></TABLE>I have the biggest selection PERIOD! I have been doing this for a while man. If someone is doing something custom and needs it, I will make it no problems.
yeegsr
15
Apr 3, 2006 06:36 PM
