replacing head gasket questions???
Old Feb 22, 2005 | 08:35 PM
93FastLs's Avatar
Default replacing head gasket questions???
it's a 94 gsr with about 160k on it.. i was thinking of doing a whole top end rebuild but useing a mugen head gasket, arp head studs plus im going to change the water pump and timing belt? but should i change the intake and exhaust valve gaskets? is anything going to happen if i do change them. i heard that i could suck oil right through them if i dont check the condtion of the pistons rings. and also if i lock the cam gears in place do i have to retime ???
Old Feb 23, 2005 | 06:26 AM
NJIN BUILDR's Avatar
Default Re: replacing head gasket questions??? (93FastLs)
Its a good time to have a valve job done and replace the valve seals(gaskets).The stock head gaskets are good pieces and less money than the mugan.If the engine is running well I would leave the head alone and just change the belt and pump.Save your money and go thru the hole engine later.
Glenn
Old Feb 23, 2005 | 03:33 PM
T.J.'s Avatar
It doesent hurt to Replace the valve stem seals and valve guides. But if your not having any major work done right now to the head them i would not bother. You wont be able to replace the valve guides your self your going to have to take it to a machine shop so that they can be pressed in. Also you or the machine shop will have to disasemble the valvetrain. IF your going to to this i would look into upgradeig your valvetrain.
Old Feb 23, 2005 | 04:36 PM
93FastLs's Avatar
aight koo thanks guys.. for the info..
yblegal
Dec 1, 2010 09:53 AM
98exowner
10
Oct 12, 2008 10:03 PM
98GSRDC2
Mar 5, 2007 10:13 AM
Y2KGreenGSR
Nov 1, 2002 06:03 PM
Austin
Jan 31, 2002 10:17 AM
