ARP rod bolts
Old Feb 22, 2005 | 07:00 PM
zman's Avatar
Default ARP rod bolts
This b18b block is supposed to have ARP rod bolts. Does it? How can you tell? Does anybody have a picture of stock rod bolts?
Old Feb 22, 2005 | 07:30 PM
vtec94civic's Avatar
it should say arp at the head of the bolt. those look stock to me because my arp's were 12 point nuts.
Old Feb 22, 2005 | 08:56 PM
PrettyLude's Avatar
Default Re: (vtec94civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec94civic &raquo;</TD></TR><TR><TD CLASS="quote">it should say arp at the head of the bolt. those look stock to me because my arp's were 12 point nuts.</TD></TR></TABLE>
it does look like stock to me
Old Feb 23, 2005 | 02:06 AM
zman's Avatar
Default Re: (PrettyLude)
Ok thanks, i figured that they were stock.
Old Feb 23, 2005 | 05:47 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (zman)
My arp rod bolts look exactly like this, they have a 6 piont nut also, not a 12 point like the 9mm vtec rod bolts. Mine are also dark black in color, as my stock rodbolts were a light greyish color
Old Feb 23, 2005 | 08:26 AM
b18a2turbo's Avatar
Default Re: (PURPLETERROR)
I had a 12 point nut , those look stock
Old Feb 23, 2005 | 09:01 AM
mmuller's Avatar
Mad Scientist
Default Re: ARP rod bolts (zman)
those are defenetely ARP bolts.
the nuts are from arp (arp's 8mm dont use the 12pt. nut)
and the stud is also arp since it has the indentation for the rods blot stretch gauge. stock ones dont
Old Feb 23, 2005 | 02:55 PM
zman's Avatar
Default Re: ARP rod bolts (mmuller)
oh, sweet. Ok cool. Do you know the torque spec for this?
This block i bought was supposed to have p73-A0 ITR pistons, which it definately does, new bearings...questionable, ARP rod bolts....apparently it does, vtec oil and water pump.....no on the water pump b/c its a 19T and the oil pump looks new but doesn't have a crank fluctuation sensor so i am not sure.
Old Feb 23, 2005 | 02:57 PM
zman's Avatar
they look identical to the the ones in this link. They have the same 6pt nut and are shaped the same on the top.
https://honda-tech.com/zerothread?id=723750
1995Civiccx
Feb 12, 2008 05:02 AM
GSROWNSU
Apr 12, 2007 11:31 PM
Honda Power
Aug 21, 2006 12:19 AM
import810
Aug 7, 2006 07:48 PM
LSVTECoupe
Sep 25, 2003 02:38 PM
