Tranny swap Question
Old Feb 22, 2005 | 05:56 PM
equinox's Avatar
Default Tranny swap Question
I have an auto 1997 honda prelude base. I'm planning on swapping the tranny with a manual. My question is: will a 96 2.3 L prelude tranny fit my engine? If so, what else might i can take from this lude in my tranny swap? Also, what parts will i still need?
Any advice will be greatly appreciated.
Old Feb 23, 2005 | 01:04 PM
equinox's Avatar
Default Re: Tranny swap Question (lude_roller)
anyone?
Old Feb 23, 2005 | 01:53 PM
Ludster's Avatar
The trannys from a H23 and an H22 are different due to gear ratios. They DO fit. But since urs is a 5th gen and ur taking parts from a 4th Gen I'm not sure if anything else would fit.
Old Feb 23, 2005 | 07:28 PM
equinox's Avatar
I hear that the 4th has longer gears? Is that good if i'm going to stay relatively stock and drive it daily?
Old Feb 23, 2005 | 09:53 PM
Ludster's Avatar
I'm not quite educated with gear ratios.. maybe some1 else on this board could help.. any1?
Old Feb 25, 2005 | 05:12 AM
19924ws's Avatar
S models have the lowest final drive
Si models have the next highest final drive
Vtecs have the highest final drive. I think you should stay with the vtec tranny so when you shift you are still in the power band.
Old Feb 25, 2005 | 06:15 AM
95PreludeSi's Avatar
Default Re: (19924ws)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19924ws &raquo;</TD></TR><TR><TD CLASS="quote">S models have the lowest final drive
Vtecs have the highest final drive. I think you should stay with the vtec tranny so when you shift you are still in the power band.</TD></TR></TABLE>
I beleive all three have the same final drive (editops, except the S). It is the gears themselves (1st,2nd,3rd, etc...) that are higher. That is right though the S has the tallest, down to the VTEC which has the lowest. Since a 4th gen VTEC is shorter than a 5th gen base I would thing the 4th gen Si would be really close to stock 5th gen.
Modified by 95PreludeSi at 3:26 PM 2/25/2005
Old Feb 25, 2005 | 06:18 AM
Default Re: (95PreludeSi)
look at the bottom of page two
https://honda-tech.com/zero...age=2
churn dasher
Jun 8, 2010 05:38 PM
Bird333
Aug 24, 2004 10:24 AM
TypeSHuTHe77uP
Oct 24, 2002 10:34 AM
