chipped p28 in my gsr ---> solid CEL
Old Feb 22, 2005 | 03:40 PM
92HB_HB's Avatar
Default chipped p28 in my gsr ---> solid CEL
Okay, this is getting really frustrating..
My chipped p72 just took a dump on me and keeps throwing a CEL 4.. so i swapped in a p28 that's also chipped for hondata.. I took out my hondata chip and put it in the p28 and started her up..
Now i get a solid CEL.. Even when I check for the code, the CEL is still solid.. What gives?? the car idles and revs fine, but the solid CEL wont go away..
Keep in mind the soldering is all good, because the p28 worked w/o any CELs in my friends ex hatch when he was running hondata..
Any suggestions?? i'm about to give up on this
Old Feb 22, 2005 | 04:44 PM
primeredbeast's Avatar
Default Re: chipped p28 in my gsr ---> solid CEL (92HB_HB)
make sure your using a good jumper when checking for the code it might just not be getting a good connection just a thought
Old Feb 22, 2005 | 10:57 PM
poison's Avatar
Is it a solid CEL w/o the jumper? Or a solid CEL with a jumper?
Old Feb 23, 2005 | 05:19 AM
92HB_HB's Avatar
Default Re: chipped p28 in my gsr ---> solid CEL (poison)
w/ and w/o the jumper..
Old Jan 28, 2010 | 01:33 PM
djnikko's Avatar
Did you manage to find a fix for this? (I know this thread is 5yrs old but still worth a try)
I have a solid CEL on a H22 EG civic swap running a P28 ECU, it dissapears when using the stock P13 ECU
Old Apr 5, 2010 | 08:13 PM
PariahBoardshop's Avatar
Hey nikko did you get your issue resolved? My p28 is doing the same thing.
Old Apr 12, 2010 | 03:58 PM
Just to put a little closure to this thread I wanted to say the resolution of my problem ended up being a new ecu. The old board looked like it was soldered correctly when it was socketed but something was wrong. I ordered a p28 from phearable and all is well.
digitaldetox
Engine Management and Tuning
Oct 5, 2010 07:23 PM
dividedas1
14
Dec 10, 2008 04:35 AM
Stingray96
Oct 31, 2005 09:38 PM
