Will the Comptech rear sway bar/tie bar combo for the Integra work on the Del Sol?
I just called up Comptech and asked if they made a rear sway bar/tie bar combo for the Del Sol and he told me the integra combo should work. He states that alot of guys are using the integra ones for Del Sol because they have the same chasis setup. Is this information true? Will the Comptech Integra sway bar/tie bar combo fit on a del sol?
well bryro...it is my professional opinion that I have no damn clue. But your Del sol looks sexy none the less...
this is AJ btw.
this is AJ btw.
Okay, I've done some part number crossreferencing and this is what I've come up with.
1. The Civic does NOT have the same rear crossmember as the Del Sol.
2. The OEM rear swaybar mounting brakets are the same for both Civic & Del Sol.
My conclusion would be that it should still fit, provided there is no additional shaping to the Del Sol subframe that would get in the way of the Comptech crossbar. All you really have to do is look underneath, and check to see if the crossmember sticks out in any wierd way...
Bryro22
Feb 25, 2005 05:44 AM
