b20z vtec
Hi I am looking at running a b20 vtec i have heard that the b20z may need bigger valve relieves? Just wanted to know if this was true i will be runnign a b16 head and ctr cams and jsut wanted to know if i would have to make the valve relieves bigger at all. any help would really be appreciated I used the search function but couldnt find what i was looking for.
thanks
thanks
as long as your head inst milled and block isnt decked, run a stock 3 layer headgasket and run stock cam gears you will be fine
as answered in other post.
Good luck on your project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92sireg »</TD></TR><TR><TD CLASS="quote">Thanks irev210 appreciate it</TD></TR></TABLE>
No problem
Built the setup myself, so, i know it works
No problem
Ihave a 99 civic si coupe the motor is being assembled right now. I was just wondering if anyone would have any idea what kinda numbers id be putting out. i've read lots of articles and forums some say b20 franks normally put out 200 with just the head swap some say more. at http://www.importreview.com/d_2.0.html they got b20 franks puttin out up to 234 hp with less mods than my motor. they also have a 200 hp si coupe @ 200 hp runnin 13.2 that sound about right? heres a list of my mods below. if you wanna check out any pics heres the link http://www.xanga.com/hybrid_syndicate
Engine Mods: (B20Vtec) Built 98 CRV Block, 99 SI Transmission, 99 SI ported & polished head, Crane Stage 2 Cam Shafts, Super Tech valves, Super Tech Dual Titanium valve springs, Super Tech Titanium retainers, AEM Tru Time Adjustable Cam Gears, Apexi Vtec Controller, AEM Short ram intake, 70mm Throttle body, Skunk 2 Intake Manifold, NGK Spark Plug Wires, Zex Plugs, AEM Fuel pressure Regulator, JE Stroker Kit ( JE 11:1 Compression Pistons, Eagle Rods, Eagle Forge Steel Crank),Golden Eagle Oil Line Kit, Jegs Fuel Pressure Gauge, ACT Street Light 12lbs Flywheel, ACT Stage 2 Xtreme Pressure Plate Clutch, DC Sport 4-1 Headers, Hi-Flow Cat,Greddy Evo Exhuast System, Pro 1 Short Shifter, Enjo Urethane Motor Mounts
Exterior: VIS OEM Carbon Fiber hood, VIS Carbon Fiber Trunk, R34 front bumper, Blitz Sideskirts, Buddy Club Rear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SI_In_Disguise »</TD></TR><TR><TD CLASS="quote">Ihave a 99 civic si coupe the motor is being assembled right now. I was just wondering if anyone would have any idea what kinda numbers id be putting out. i've read lots of articles and forums some say b20 franks normally put out 200 with just the head swap some say more. at http://www.importreview.com/d_2.0.html they got b20 franks puttin out up to 234 hp with less mods than my motor. they also have a 200 hp si coupe @ 200 hp runnin 13.2 that sound about right? heres a list of my mods below. if you wanna check out any pics heres the link http://www.xanga.com/hybrid_syndicate
man thats like the 5th time ive seen you post the same thing lol.......WHY DONT YOU DYNO YOUR ****?
seriously, just go dyno your engine.
THis thread has nothing to do with your engine setup, why are you posting it here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 »</TD></TR><TR><TD CLASS="quote">
THis thread has nothing to do with your engine setup, why are you posting it here?</TD></TR></TABLE>
I know what youre saying. That same guy came into my own thread and posted that same exact post down to the last "." Now seriosly! SI_In_Disguise go get your own thread and ask someone or just get your motor done and find out for yourself. Geez! Go check my thread https://honda-tech.com/zerothread?id=1162145 (under my friends account) and you can see he did the same thing there and if you have the knowlege to answer any of my questions in there-please feel free.
SiRstewart99
Aug 24, 2012 08:04 AM
