Timing Belt Play
Old Feb 22, 2005 | 01:28 PM
metalgears's Avatar
Default Timing Belt Play
I just put back my stock cams and I noticed that the timing belt has alot of play on it.
I have the timing belt cover off and i can see it wobbling at idle.
Is this normal?
Old Feb 22, 2005 | 02:15 PM
Greyout's Avatar
Default Re: Timing Belt Play (metalgears)
no
is this an H22 or H23?
Old Feb 22, 2005 | 02:18 PM
blackdelslo's Avatar
Default Re: Timing Belt Play (Greyout)
If you put it on correctly it should be fairly hard to get it on.
Hawkze_2.3's Avatar
Definately not normal. Sometimes with the manual tensioner I have to manually tighten the belt by pulling on the tensioner (if that's what you have). If you have an auto tensioner, you need to switch over.
Old Feb 22, 2005 | 02:23 PM
metalgears's Avatar
Default Re: Timing Belt Play (Hawkze_2.3)
JDM H22 guys.
The belt was a bitch to put on (also kept losing them damn keys for the cams )
After I put the belt over the cams i retighten the autotensioner.
Should i have done anything before i locked it down?
Old Feb 22, 2005 | 10:09 PM
PrettyLude's Avatar
get a new autotensioner or convert to the manual one, i have seen many autotensioners collaspe because of reusing it
Old Feb 23, 2005 | 03:21 AM
94_HATCH's Avatar
Default Re: (PrettyLude)
I reused my auto tensioner on my 99 h22a4 when i did my swap....that bitch tightend right up after i bolted it on.
Old Feb 23, 2005 | 12:25 PM
nslude's Avatar
Default Re: (94_HATCH)
i put an h23 head on my f22...used the f22 manual tensioner (has the same part # as h23) i have 1/2 inch slack on front part of belt (facing front of car) tensioner is maxed out...no play on top of cams..or on rear of motor...where the tensioner is...pulled it off a number of times and tryed again same thing..
Old Mar 9, 2005 | 01:47 PM
SLC-lude93's Avatar
Default Re: (nslude)
"i put an h23 head on my f22...used the f22 manual tensioner (has the same part # as h23) i have 1/2 inch slack on front part of belt (facing front of car) tensioner is maxed out...no play on top of cams..or on rear of motor...where the tensioner is...pulled it off a number of times and tryed again same thing.."
The same thing is happening to my h22a1, except i'm using an auto tensioner (brand new only been put on once). I left the top t-cover off to watch the belt and it's shaking bad. I don't know whats wrong, ive pulled it off and and dissassebled the entire front of the engine and put it back together and it still does the same thing. I've replaced everything so I know everything is in perfect condition. I also have noticed that the belt creeps off the cam gears maybe a 1/16 of an inch. Does anyone know what is going on?
Old Nov 8, 2005 | 04:55 PM
DJ Chronic's Avatar
Default Re: (SLC-lude93) timing belt
I do not mean to bother you but i have the same problem with mine, about the timing belt being loose on the front side of the engine. If you have found the problem would you let me know.
H22LUDE808
Mar 7, 2008 09:18 PM
Stuartz
May 1, 2007 07:48 AM
93LudeVtec
Feb 3, 2003 06:15 PM
