B16 REVING PROBLEM
Old Feb 22, 2005 | 01:08 PM
demdem's Avatar
Default B16 REVING PROBLEM
My b16 use to to throttle at 800rpm now it start to trottle at 1500 rpm and sometimes to 2000rpm I try turning down the throttle and still not turn down what could be the problem
Old Feb 22, 2005 | 01:51 PM
89s1's Avatar
Default Re: B16 REVING PROBLEM (demdem)
the problem seems to be your grasp on the english language...
but i'll bet on a vaccuum leak
Old Feb 22, 2005 | 04:34 PM
00ekhatch's Avatar
is the check engine light coming on? if so what code is it?, ive heard of a TPS sensor causing a high idle, as well as loose vacume line, or even the AICV
Old Feb 22, 2005 | 05:31 PM
eda6's Avatar
Default Re: B16 REVING PROBLEM (00ekhatch)
It's probably the fitv. Take it apart, inside you'll find a screw, bottom it out.
Old Feb 22, 2005 | 06:49 PM
demdem's Avatar
Default Re: B16 REVING PROBLEM (eda6)
oh ok i check for a vaccum leak there is none and I clean out the T-body check the gas cable and everything is ok just a while a go i was pushing the car and now it reving at 3000rpm now. REALLY NEED SOME HELP!!!!!!!!!!!!!!
Old Feb 22, 2005 | 07:20 PM
demdem's Avatar
What is the FITV and where is it located
Old Feb 22, 2005 | 07:40 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by demdem &raquo;</TD></TR><TR><TD CLASS="quote">What is the FITV and where is it located </TD></TR></TABLE>
fitv=fast idle thermo valve. Located below your throttle body.
Old Feb 22, 2005 | 07:44 PM
demdem's Avatar
exactly where and what it look like
Old Feb 22, 2005 | 08:47 PM
eda6's Avatar
https://honda-tech.com/zerothread?id=699787
directly below the throttle body
Old Feb 22, 2005 | 11:09 PM
poison's Avatar
Make sure your throttle cable is also not tight on between the throttle bracket and the throttle rotor.
Old Feb 23, 2005 | 07:15 AM
demdem's Avatar
Default Re: B16 REVING PROBLEM (poison)
i check the cable already
Old Feb 24, 2005 | 05:22 PM
demdem's Avatar
thanks anyway people fix problem
Old Feb 26, 2005 | 11:51 AM
my crx is rhd's Avatar
what was the problem, thats the point of this site, to learn from other peoples problem man....what was it, i got the same thing goin on!
black95delsol
Apr 16, 2009 08:47 AM
davenport517
13
Apr 21, 2008 11:27 AM
hybridbmw
May 8, 2005 01:58 PM
Kaneo
Feb 2, 2005 06:23 PM
CrRexSiR
25
Mar 29, 2004 05:46 PM
