need help installing an injector resistor box.
Old Feb 22, 2005 | 12:04 PM
vtec-adykt's Avatar
Default need help installing an injector resistor box.
i plan on buying a resistor box from an obd1 honda to use with my 450cc dsm injectors. but i dont know how it needs to be rigged to make it work. do i just connect one of the injector wires to any of the wires of the resistor box? some one was also telling me i could go to radio shack and get some kind of resistors for cheap and it would work just the same. if so, which colored wire do they splice into? thanks for the help.
heres my setup:
garrett t3/t04e
2.5" d.p.
2.5" i.c. piping
hks ssqv bov
tial 35mm w.g.
uberdata w/basemap
450cc dsm injectors
Old Feb 22, 2005 | 12:26 PM
4_door_teg's Avatar
Default Re: need help installing an injector resistor box. (lazyeyez)
If you're using resistors
Resistor box
hope that helps
*copied from g2ic turbo guide
Old Feb 22, 2005 | 12:33 PM
primeredbeast's Avatar
searching is the shitt saves you time
https://honda-tech.com/zerothread?id=517274
check this out everything you need to know
Old Feb 22, 2005 | 12:35 PM
vtec-adykt's Avatar
Default Re: need help installing an injector resistor box. (4_door_teg)
this will definitely help! thanks bro!
Old Feb 22, 2005 | 12:41 PM
vtec-adykt's Avatar
oh! i forgot to mention that it is a 1995 b18c motor in a 1995 civic ex. will the color diagram still be the same?
Old Feb 22, 2005 | 12:46 PM
all obd-1 should be the same
Old Feb 22, 2005 | 12:50 PM
4_door_teg's Avatar
Yea it should be the same. I just read your original post again and you said you were going to get a resistor box out of an obd1 car. You actually need a resistor box out of an obd0 car.
Old Feb 22, 2005 | 12:56 PM
vtec-adykt's Avatar
Default Re: (4_door_teg)
would a 1992 honda accord be an obd0?
Old Feb 22, 2005 | 12:59 PM
RotiEatter's Avatar
Ditto
Default Re: (lazyeyez)
no that would be obd1, but that is fine as well, no difference besides the plug.
Old Feb 22, 2005 | 01:04 PM
vtec-adykt's Avatar
Default Re: (RotiEatter)
o.k. so what else would i need besides the resistor box to make it happen. any kind of special harness?
Old Feb 22, 2005 | 01:05 PM
check out the link that i posted has pictures and everything fool proof
Old Feb 22, 2005 | 01:14 PM
DaX's Avatar
DaX
Loved
Community Favorite
Search the H-T knowledge base for 'resistor box' ...I've done an extensive writeup there.
evosix
Jun 4, 2008 06:41 PM
yodas-gsr
Oct 24, 2005 01:41 AM
Licensed2Spool
Apr 12, 2003 10:51 AM
