what probs will i run into swapping a jdm type r head on a U.S. B16 motor?
Old Feb 22, 2005 | 10:30 AM
fasterhatch's Avatar
Default what probs will i run into swapping a jdm type r head on a U.S. B16 motor?
what probs will i run into swapping a jdm type r head on a U.S. B16 motor? i originally wanted to get the type r cams but i am very interested in swapping heads. i want a fast car but i also want it to be as reliable and i think swapping the heads will reduce risk than trying to put in just the cams; am i wrong?
i will get the hondata S200 unit also.
thanks for the help
Old Feb 22, 2005 | 11:00 AM
SwapShopR's Avatar
No Sales Forums
Default Re: what probs will i run into swapping a jdm type r head on a U.S. B16 motor? (fasterhatch)
No problems. But while you have the head off, I would suggest purchasing & installing a high-rev valve train. This is safer & will save you some time & cash down the road.
Old Feb 22, 2005 | 11:15 AM
Soccerking3000's Avatar
Default Re: what probs will i run into swapping a jdm type r head on a U.S. B16 motor? (SwapShopR)
if he is only planning on putting type-r cams in then he doesnt need to upgrade anything, just swap the head, if it is actually a type-r head and type r **** in it then you wont sacrifice reliability or anything
Old Feb 22, 2005 | 06:24 PM
SwapShopR's Avatar
No Sales Forums
Default Re: what probs will i run into swapping a jdm type r head on a U.S. B16 motor? (Soccerking3000)
I never said you needed 2, it's just a good idea.
santiagoazn89
Oct 1, 2010 06:31 AM
v!taminb16
13
Feb 15, 2008 07:01 PM
Nextelbuddy
May 30, 2003 11:01 AM
