H22 injectors on h23?
Old Feb 22, 2005 | 07:13 AM
92silude's Avatar
Default H22 injectors on h23?
someone told me that I should put h22 injectors on my h23...you guys ever hear of this, and what advantages does this have?
Old Feb 22, 2005 | 01:09 PM
fastlude69's Avatar
only thing is that they are bigger so if you need more fuel which you don't according to your mods so i wouldn't bother
Old Feb 22, 2005 | 10:11 PM
PrettyLude's Avatar
depends on what year the h22 motor is, the obd1 have 345 and the h23 have 345, the newer obd 2 has 290
Old Feb 22, 2005 | 10:41 PM
Eddiebx's Avatar
the h23 comes with 345cc as well? i always thought it would be lower than an h22, heh
Old Feb 23, 2005 | 06:57 AM
Ludster's Avatar
Default Re: (Eddiebx)
I always thought the h23 had the 240s and the h22 had the 345 due to VTEC..?
Old Feb 23, 2005 | 07:00 AM
prelittlelude's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">depends on what year the h22 motor is, the obd1 have 345 and the h23 have 345, the newer obd 2 has 290</TD></TR></TABLE>
he made a typo,
the h23 has 240s
the obd1 h22 has 345s
and the h22a4 had 290s
to answer the question: there is no point in upgrading your injectors unless you have an after market fuel managment system , or some other way to indicate that you are almost maxing out your stock 240s due to your moddifications.
if you are all motor and have increased hp enough then with some type of fuel managment and wide band o2 tuning you could upgrade your injectors to the obd1 345s or remove the resistor pack and add obd2 injeector clips and use the 290s
Old Feb 23, 2005 | 07:15 AM
Ludster's Avatar
Default Re: (prelittlelude)
That answers it
Old Feb 23, 2005 | 07:22 AM
Anova's Avatar
Default Re: (Ludster)
is there a way to see if my injectors are H23 or H22? i bought a set of ebay, claiming they are H22, but I wanna make sure!
Old Feb 23, 2005 | 01:41 PM
Ludster's Avatar
Default Re: (Anova)
There should be a number imprinted on the injectors stating how many CC's they are. Just match the numbers up top and you'll find out
Old Feb 24, 2005 | 07:20 AM
Anova's Avatar
i dont see a number anywhere...they are used injectors....would the injectors look any different, i.e. size difference?
Old Feb 24, 2005 | 09:45 AM
killa_lude's Avatar
Default Re: (Anova)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anova &raquo;</TD></TR><TR><TD CLASS="quote">i dont see a number anywhere...they are used injectors....would the injectors look any different, i.e. size difference?</TD></TR></TABLE>
No the injectors look basically the same. They should fit the same as well.
Old Feb 24, 2005 | 01:12 PM
PirateMcFred's Avatar
*sigh* I know I posted this before but I suppose that it can't hurt to do it again:
Each injector is OBD1. On the left is the 345cc/min H22A injector with green tip and blue paint. On the right side is the 235cc/min H23A injector with clear-ish tan tip and white paint.
Pirate
asmallsol
Aug 23, 2006 03:58 AM
yohan
Sep 27, 2004 08:33 PM
SAVIOVEGA
Jul 31, 2004 04:36 PM
trev4
Jul 21, 2004 10:25 AM
