99-00 Si Tranny
Old Feb 21, 2005 | 11:26 PM
.Ryan's Avatar
Don't Trust Anyone
Default 99-00 Si Tranny
Will a '99-'00 Civic Si Tranny bolt right up to a '00 B18? What will I need? Should I do a clutch/flywheel swap before installing?
Old Feb 21, 2005 | 11:34 PM
pr_tony_montana's Avatar
Default Re: 99-00 Si Tranny (Silent Bob)
the 00 si tranny will work, I would upgrade the clutch and flywheel since the tranny is being dropped if there is a lot of miles on the old clutch and flywheel. accleration will be quicker w/ si tranny but hwy crusing will be higher in the rpms which will give you a little worse gas milage.
Old Feb 21, 2005 | 11:36 PM
JDMlyfestyle's Avatar
Id go with a GSR tranny on a LS. think the Si tranny would spin up a lil too fast for the LS.
Old Feb 22, 2005 | 12:21 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: (JDMlyfestyle)
I believe my lil bro is wanting to do LS/VTEC. Isn't the 00 Si tranny geared the same as the itr?
Old Feb 22, 2005 | 12:24 PM
Dacalac's Avatar
Default Re: (Silent Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silent Bob &raquo;</TD></TR><TR><TD CLASS="quote">I believe my lil bro is wanting to do LS/VTEC. Isn't the 00 Si tranny geared the same as the itr?</TD></TR></TABLE>
I thought it was the CTR that it shared similar gearing ratios with.
Old Feb 22, 2005 | 12:27 PM
Padawan's Avatar
Darth ModerVader
Yes, the '99-'00 Si and the USDM ITR share identical gear and final drive ratios.
Old Feb 22, 2005 | 01:31 PM
Equilibrium's Avatar
* B A N N E D *
Just know, the B16 tranny will wind up a lot faster, which means if you're going for full on drag 1/4 mile, this'll be the tranny for you (although LSD would be nice, I guess you could upgrade later). If you want a good highway, semi-drag, and all around transmission, get a GSR. Other than that, if you want a nice turbo/economical transmission, get the LS.
Old Feb 22, 2005 | 08:10 PM
.Ryan's Avatar
Don't Trust Anyone
Default Re: 99-00 Si Tranny (Equilibrium)
Anyone recommend a nice clutch/flywheel set up?
Old Feb 22, 2005 | 08:12 PM
alphanumeric's Avatar
Default Re: 99-00 Si Tranny (SHAGGY)
go fidanza!!
Old Feb 22, 2005 | 09:51 PM
tcr03's Avatar
ive got an ls/vtec, with a si tranny. i love it. gas mileage sucks though. but it is quick
r0guish
Jun 15, 2005 09:44 PM
Darksoul
Mar 7, 2005 05:43 PM
rusteds2k
May 26, 2003 10:20 PM
greengsrss1320
Feb 5, 2002 11:36 PM
