What dizzy will BOLT UP to Sir II B16 ?
Old Feb 21, 2005 | 11:11 PM
Jasno161's Avatar
Default What dizzy will BOLT UP to Sir II B16 ?
My dizzy is bad, after using a 95 Del Sol Vtec, and see'ing that it doesnt bolt up correctly, I dont know what to buy.
Anyone know what dizzy I can use for JDM odb1 B16A Sir II? One that bolts up right...
Old Feb 22, 2005 | 12:29 AM
dantastic's Avatar
Default Re: What dizzy will BOLT UP to Sir II B16 ? (Jasno161)
the del sol DOHC vtec distributor should work fine. the SOHC vtec distributor won't work. you can also use a 92-95 Integra GSR DOHC vtec distributor.
be careful when you ask for parts for the "VTEC Del Sol". parts get incorrectly cross listed between dohc vtec and sohc vtecI often got D16z6 parts instead of B16a parts. i went to autozone to buy a timing belt, and they gave me a d16z6 belt that was listed under "dohc vtec". i also needed a new altenator, and pep boys gave me a d-series one instead of a b-series one.
Old Feb 22, 2005 | 01:26 AM
RangerDan's Avatar
Default Re: What dizzy will BOLT UP to Sir II B16 ? (dantastic)
I had to replace the one on my SiR...which of course had the b16...anyways the part number off the receipt is A1C 31-17407
Old Feb 22, 2005 | 01:56 PM
Jasno161's Avatar
Default Re: What dizzy will BOLT UP to Sir II B16 ? (RangerDan)
Yeah of course its special order part, god..Thanks tho
Old Feb 22, 2005 | 02:11 PM
doublejz's Avatar
i replaced mine with a del sol vtec and it worked fine from distributor king. Their site is under construction at the moment but they still have listings on ebay http://cgi.ebay.com/ebaymotors...33690
Old Feb 22, 2005 | 02:31 PM
Jasno161's Avatar
Default Re: What dizzy will BOLT UP to Sir II B16 ? (doublejz)
Well I called Kragen and they said they have the dizzy that is part # A1C 31 17407, auto zone said they would have to order it. So im gonna run and see if thats it..
Old Feb 22, 2005 | 02:34 PM
gobblebox59's Avatar
u just had a thread with this same **** and ur question was answered like 5 times, omg.
Old Feb 22, 2005 | 02:36 PM
dantastic's Avatar
if you can wait, get one off ebay. they have "new" (probably rebuilt) dizzys for $180 shipped. they go for $240+ at kragen w/o cap can rotor. the ebay ones even have 5yr warranties
Old Feb 22, 2005 | 02:37 PM
Jasno161's Avatar
Default Re: What dizzy will BOLT UP to Sir II B16 ? (gobblebox59)
Actually no the thread was crowded so I made a new one so people didnt have to read the whole thing to get whats going on.
No one ever answered what dizzy I could be using, so far everyones asnwer on what dizzy was a wrong dizzy when I got down there. The only one that I havnt seen yet is the one part # on this thread..So just dont talk if your gonna flame like a retard, no one wants to look at a thread with 2 pages, so I made a new one to make it easy..
Old Feb 22, 2005 | 02:48 PM
Jasno161's Avatar
Default Re: (dantastic)
The problem is I watched them pull up DOHC Vtec and the part number was like 17404, and thats what everyone has in stock, which doesnt bolt up. One store has the 17407 so im hoping hes not a moron and actually has it, because last time I was there 2 days ago he had a different one but said it was the dohc vtec del sol dizzy..
Old Feb 22, 2005 | 02:56 PM
mental1's Avatar
I used my friends GSR distributor to see if that was my problem on my B16, and it bolted up fine. However, since he will eventually will need that back, I took the insides out of my original CX dist. put them in the B16 dist. and now I have a perfectly working B16 dist. Of course now that I think about it that means all the moving parts are worn a bit more than on a new one but I'm poor and it works for the moment, so I guess that's good enough.
In other words if you must have a brand new one, get one for a Integra GSR of the same OBD as the car you are putting it into, I'm sure there's one from a del sol that would work to but I never looked into it that far.
The parts store in my town likes selling me the wrong parts also. I really confuse now asking for Integra parts than asking for del sol and civic parts.
Modified by mental1 at 4:08 PM 2/22/2005
Old Feb 22, 2005 | 03:03 PM
Jasno161's Avatar
Default Re: (mental1)
Yeah they are all special order so I didnt wanna pay hella money and wait just yet..
I would swap my internals except the fact that kragen stripped the rotor screw and I cant get the internals off...
Old Feb 22, 2005 | 03:10 PM
mental1's Avatar
If you plan on changing the rotor anyways just break it and get a vicegrip on the screw that's how I did mine.
honda etr (vw)
May 21, 2005 08:46 AM
EFMAN
Apr 5, 2005 11:52 AM
Integra_Boi
May 8, 2004 07:26 AM
Sterling
12
Jul 17, 2002 06:12 AM
prjctCIVIC
Mar 19, 2002 08:04 PM
